Is this cam to much? Custom Grind 427 4x4
Old Sep 2, 2022 | 09:37 PM
FireFall95's Avatar
Default Is this cam to much? Custom Grind 427 4x4
I have an 02 2500hd with a 2600 stall 4l80e 35s 4.10 gears im building a dart 427 4.125 bore x 4.000 stroke and some afr cathedral port 245s I'm using the TBSS intake my question is its I'm using it as a daily driver 4x4 with occasional towing a few times a year will i lose bottom end with this cam it was custom speced what's your opinions?
Old Sep 2, 2022 | 09:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
If you were realistic with your goals, I don't think you will. That is probably like a stage 2 high lift cam on a smaller cubic inch motor.
Old Sep 2, 2022 | 10:10 PM
FireFall95's Avatar
I'm just afraid of losing towing ability like towing a car once in a while but I think it'll be fine I mostly daily drive it Launch from lights or 4 wheel offroad
Old Sep 2, 2022 | 10:12 PM
1FastBrick's Avatar
a 230 intake duration on 427 with a head that can move air is mild. Its like a 220 on a 6.0L
Old Sep 3, 2022 | 07:33 AM
68Formula's Avatar
Should work well for what you want.
Hellfire77
Jan 11, 2022 07:15 AM
DoogieLee
Mar 18, 2015 12:19 AM
NextLevel
35
Oct 10, 2010 12:16 AM
slowlsx
Apr 28, 2009 01:38 PM
white1
Sep 14, 2006 12:15 AM
