cam install question
Old May 22, 2006 | 02:21 PM
Jeff Alexander's Avatar
Default cam install question
for those of you that have automatic trans how did you stop the engine from turning when you remove or installed the balancer. any special tools or just take the starter out and hold the flexplate with a pry bar
Old May 22, 2006 | 02:28 PM
white1's Avatar
Prybar for removal, and torch for installation, then prybar to torque.
Old May 22, 2006 | 03:12 PM
speedy02's Avatar
I use a impact gun..
Old May 22, 2006 | 04:27 PM
is that going to be enough torque by just using an impact gun. your suspost to torque it to 37LBs then rotate 140degrees
Old May 22, 2006 | 04:30 PM
thunder550's Avatar
High on diesel fumes
I doubt an impact gun can do this. I put a long wrench around one of my converter feet and got it to wedge up against one of my headers, then went to town with a 2' breaker bar, all my weight and strength into it and I still couldn't get it 140*. Got close though, and I have my crank pinned so I'm not too worried about it. That thing is a bitch though!!
BTW, I have a 4L80E, not sure if you can do the same with the 60. With the 80 there is a converter cover that comes off and gives you access to the entire lower half of the converter.
Old May 22, 2006 | 04:49 PM
im not sure about the cover got to check it out
Old May 22, 2006 | 04:56 PM
thunder550's Avatar
The 4L60E is a one-piece bellhousing, so you don't have a cover. You might be able to squeeze a wrench into the starter hole and get it that way.
Old May 22, 2006 | 05:01 PM
adrenalinep's Avatar
I used an impact, not just anyone will work mine didnt have enough *****. I used my buddies ingersoll rand , he said it was good for 400 lbs torque
Old May 26, 2006 | 12:06 AM
eallanboggs's Avatar
I use a plumber chain wrench around the pulley itself. Don't have to worry about the torque converter that way.
Old May 26, 2006 | 12:12 AM
desTRUCKtive's Avatar
if you have a good 3/4 impact gun it will take it right off.
