cam install question
for those of you that have automatic trans how did you stop the engine from turning when you remove or installed the balancer. any special tools or just take the starter out and hold the flexplate with a pry bar
Originally Posted by Jeff Alexander
is that going to be enough torque by just using an impact gun. your suspost to torque it to 37LBs then rotate 140degrees
BTW, I have a 4L80E, not sure if you can do the same with the 60. With the 80 there is a converter cover that comes off and gives you access to the entire lower half of the converter.
