cam install
Old Aug 15, 2013 | 07:01 AM
tim wellington's Avatar
Default cam install
my truck was cammed when i bought it .now my buddy wants me to do his . i am told you can remove the rockers and push rods and rotate cam after timing cover is remove and lifters will set in plastics holders until swap cam .is there any thing else?
Old Aug 15, 2013 | 07:08 AM
Dangeruss5.3's Avatar
i have seen people do this. The only thing that I have heard of is that if its a higher mileage motor that the buckets wont hold the lifters and they can fall out. Let me know how it goes.
Old Aug 15, 2013 | 07:10 AM
fastjweb's Avatar
yeah man, after you rotate the cam to push up the lifters, you need to slide som e long dowels into the holes in the block that are on each side of the cam, this will make sure the lifters stay up without dropping back down on you. Just look up ls cam swap pics on google, it will show what im talking about.
Old Aug 15, 2013 | 07:21 AM
Nice idea! Never thought of that. Would have saved me some time pulling my motor. I guess I should have done some research first. lol
Old Aug 15, 2013 | 10:41 AM
53bowtie's Avatar
You will also have to pull the radiator but I think the condenser can be left connected so you shouldnt have to mess with the AC at all. Like said above you can use some dowels to hold the lifters up or Comp Cams sells a tool that you can use as well. Also, I have seen some people use cheap magnets that parts stores have on their counter at the register to hold them up in place.
Old Aug 16, 2013 | 12:16 AM
grey matter 04's Avatar
13 Second Truck Club
5/16 wooden dowels will hold the lifters up
I have a set I use on cam swaps that's cut to length
Old Aug 16, 2013 | 12:24 AM
brandon6.0's Avatar
^^ same thing i have used. Works perfect!
Old Aug 16, 2013 | 04:26 AM
Noah Burns's Avatar
dowels worked perfect for me every time as well! as for higher mileage, idk about that, I did cam swaps on my first "ls" motor when it had well over 100k on it with no dowels and no magnets and never had an issue. it's all about luck if you use that method!
Old Aug 16, 2013 | 09:09 AM
darnie's Avatar
LS1Howto.com
it has everything...
Old Aug 16, 2013 | 01:40 PM
Choda's Avatar
great write up ^^^^^^
