Cam install
What I have
1. LS1 how to guide
2. VHP 08 "ultra tq" cam
3. VHP sping kit including springs and retainers
4. spring compressor with air pressure adapter to pressurize the cylinders
5. hardend pushrods
Since this is my summer DD I'm super nervous
Am I missing anything else... do I need lifters too?
How about a new crank bolt?
Gaskets?
Also how long should this take me... one day with two people perhaps?
1. LS1 how to guide
5. hardend pushrods
Gaskets?
You might want to buy 8 of those pen magnets to hold the lifters up,or your playing russian roulette,also some cam lube,coolant,and all your gaskets,plus most important the right tools
- SDPC Gasket Kit w/new crank bolt
- Spring/Retainer locks (don't want your cam install to go on hold for a $0.03 part)
- Food, Gatorade, Water
- Icy hot/Tiger Balm
- Computer (so you can run to us with your problems)
don't waste your money on $70 worth of pen magnets. Just buy a 3" long piece of 5/16th's metal rod and cut it in half. Grind a groove all the way down both pieces and stick them in the cam journals. This will hold your lifters up.
We used this method to hold my lifters up for 2 straight days and didn't have a single problem.
Originally Posted by BURLS1
$1.49 @ harbor freight for pen magnets $1.49x8=$11.92,plus you can use them for many other things later,and no "home machining"req'd.....$70 what are they 24k gold plated
-Lurius
Originally Posted by PSM
What I have
1. LS1 how to guide
5. hardend pushrods
Gaskets?
1. LS1 how to guide
5. hardend pushrods
Gaskets?
