Cam install
Old Dec 20, 2006 | 08:33 PM
  #21
Last Call's Avatar
TOTM: January 2007
Originally Posted by The Breeze
Ok well I just got back getting the truck tuned I am puttin down 396 hp @ 5500 rpm and 399 torque @ 4850 rpm this is with a 2.9 pulley I am seeing 8 lbs of boost and 12* of timing. That is a 40 hp gain and 48 torque over the old 3.1 pulley and stock cam
Great gains Bryan. It is always good to see solid gains when doing mods. Now get to the track and hit that 11!!!
Old Dec 20, 2006 | 08:39 PM
  #22
dewmanshu's Avatar
Moderately Differentiated
out of curiousity...what were you expecting? I was hoping to see 400's outta ya. Hell of gains nevertheless. Is 12* all that they could get before kr or is that what everyone just felt comfortable with?
  #23
Breeze's Avatar
11 Second Truck Club
The thing of it is the #s seem low I dont know if its the dyno or what but track times are real. 12* is what he recommended I run.
Old Dec 20, 2006 | 10:10 PM
  #24
ss04flores's Avatar
were can i get some for my 04 ss silverado
Old Dec 20, 2006 | 10:12 PM
  #25
1SlowHoe's Avatar
Destroyer of Transmissions
Some what?
Old Dec 21, 2006 | 09:40 AM
  #26
Last Call's Avatar
TOTM: January 2007
I ran 18 without the meth. 21 with it. Almost exact same set up.
Old Dec 21, 2006 | 10:02 AM
  #27
dewmanshu's Avatar
i am not dyno smart...the mustang dyno...less ratings than others right?
j what's your dyno rating on? dynajet?
nevertheless, 18* versus 12* is a BIG BIG power difference. There's alot of power on the table and if kr is in the way then it needs to be dealt with another way instead of just lowering the timing IMO. A 2.9 pulley may cause quick heat, but no reason to start out at 12*. I am no professional tuner by any means, but seems ridiculously low. I say 11's are not coming his way with 12*'s of spark.
btw, i have stock radix setup (70mm) with a 2.8 pulley and run what j's runs with spark. 18* and if I used the meth (not currently) I can get 21* out of it. I can even start the 1320 at 18* and end at 18* in these current days. Okay okay, maybe end at 16* sometimes. Obviously not during July.
Old Dec 21, 2006 | 10:08 AM
  #28
thunder550's Avatar
High on diesel fumes
I was running around 17-18* also with no meth on my 6.0 with a 2.8" pulley. You should definitely be able to get more timing than 12*.
Old Dec 21, 2006 | 10:21 AM
  #29
ZR1 DREAMING's Avatar
Solid gain Breeze, I honestly was expecting a little more but a solid gain nonetheless. And yes, a Mustang dyno traditionally reads #s lower than most other dynos.
Old Dec 21, 2006 | 10:38 AM
  #30
BLK02WS6's Avatar
9 Second Club
Hey guys - Bryan's tuner here. I was takin it easy on the timing cause I didn't realize it was a lower compression engine (I'm used to dealing with the cars and 10.25:1 and up). We tried some more timing on one pull and the power fell off - probably do to heat-up from multiple pulls. Never saw any KR at all though. Now that I know the compression ratio, we are gonna strap it back down tonight - I'm sure there is more in there. Sorry Bryan, guess I shoulda asked about the CR instead of assuming. We'll see what else we can get tonight.
