cam help on 6.2 denali
Old Aug 26, 2010 | 04:48 PM
05crew's Avatar
Default cam help on 6.2 denali
what all is need for a cam swap? dont know much about the VVT or DOD...hell not sure if it has what? but i just have been looking for a cam for the truck and not sure how big to go...or what all has to be changed?
thanks for the info
Old Aug 26, 2010 | 08:37 PM
05crew's Avatar
any info would help?
Old Aug 26, 2010 | 08:41 PM
skoal bandit's Avatar
i think you can get VVT cams. don't know what all needs to get changed on VVT. you should have VVT and not DOD. i thought there was a thread already about that. have you tried doing a search?
Old Aug 26, 2010 | 08:50 PM
http://www.thunderracing.com/shop-by...T.-and-D.O.D./
Old Aug 26, 2010 | 09:28 PM
iamkeniff's Avatar
they make a Phaser kit for the VVT but i say go without the VVT bc i dont trust the spring to determine what my cam advancement is.
i deleted my VVT and ran a 3 bolt cam.
Old Aug 26, 2010 | 11:01 PM
supercharged680's Avatar
X2 on the 3 bolt cam
Old Aug 27, 2010 | 02:49 PM
05crew's Avatar
ya sorry i did not make it clear...i dont want to run a vvt cam...what all do i have to change to run a 3 bolt cam...the old set up and the cam i used i liked..looking for somthing in that range..but do i have to change the lifters and ????
Old Sep 2, 2010 | 11:30 AM
hog's Avatar
hog
VVT is a pretty cool setup, it allows for good low rpm torque and good upper rpm power. It in effect is like having 2 cams in 1.
There seems to be quite the negativity towards VVT. Its good to see that Comp is doing the VVT cams.
PCM tuning the VVT would be quite a bit more com,plicated as tuning for all the different cam phasing events would need to be done for a PROPE PCM tune.
So long as the trend for more power from similar or smaller displacements continues, the OEMs will be forced to use technologies like this. this is esp. important in truck as they are used to tow. Customers who do tow need low rpm torque for towing, but GM needs the big power number to be competitive and sell trucks. VVT is just like the VTEC systems that Honda uses.
I look forward to the GENV smallblocks.
peace
Hog
Old Sep 2, 2010 | 01:59 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
peace
Hog
Id have to agree, but I only know of one tuner who even knows how to proprely tune a VVT setup and he needs the vehicle in person and he is in Texas.
Old Sep 2, 2010 | 02:12 PM
iamkeniff's Avatar
Pat G
i say get a pat g cam and have fun! lol.
zo6freak
14
Oct 18, 2015 06:43 PM
rudvirus
Aug 5, 2015 08:05 PM
Ammadien
Jul 22, 2015 08:50 PM
low2001gmc
Jul 21, 2015 02:09 PM
03sierraslt
Jul 11, 2015 02:47 PM
