CAM choice: TSP 228R or Lunati Voodoo?
Old 05-16-2012, 06:16 PM
fst100's Avatar
Question CAM choice: TSP 228R or Lunati Voodoo?
im in a cross road on which cam to go with for my LQ4 motor. i plan on getting double valvesprings along with 7.4" pushrods in either cam choice. will be doing some angle valve job on the 317 heads as well and thats it in regards to the valvetrain. for the cam i dont plan on revving it above 6500 and dont really want to reaplce valvesprings every 20k miles so the cams above the lifts are below or just at .600.
i know a handful of ppl run the 228R but what about lunati cams? the one im particularly looking at is the Voodoo Hyd Roller Cam - LS1 LS2 282/288:
Advertised Duration (Int/Exh): 282/288
Duration @ .050 (Int/Exh): 232/238
Gross Valve Lift (Int/Exh): .599"/.601"
LSA/ICL: 113/109
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2400-7000
thoughts?
Old 05-16-2012, 06:39 PM
ltr450ryder's Avatar
The voodoo one will a bigger stall then the tsp. But first questions. what's the lq4 in rcsb ecsb ccsb 2x4 4x4 gears what u plan to do with it tow race etc.
Old 05-16-2012, 06:55 PM
fst100's Avatar
what do you mean bigger 'stall'? the lq4 is going into a 98 firebird....racing.
Old 05-19-2012, 12:37 AM
Un-Registered User
mcfarlnd's Avatar
He means a "higher stalling" torque converter.
Old 05-19-2012, 12:45 AM
fst100's Avatar
Okay I figured that was what he was asking. I plan on getting something like a 3400 stall in the near future.
Old 05-19-2012, 08:10 AM
11 Second Truck Club
MPFD's Avatar
Get a 3600 and do that first...
Old 05-21-2012, 09:12 PM
fst100's Avatar
Exclamation
i'll do that evetually. here's my check list for the motor and please feel free to let me know if im missing anything else or the parts i have would be in conflict with each other:
-lunati cam 60512
-either Patriot Gold LS Dual Valve Spring & Titanium Retainers Kit or lunati Gold Dual Valve Spring Kit
-7.40" pushrods
-ls7 oil lifters
-ls2 lifter trays
-ls2 timign chain
-ARP head bolts
-FELPRO head gasket kit
-ported oil pump
-typical cam install kit
im reusing the LQ4 rockers as they're the same as the LS1 correct? anything else please let me know
Old 05-22-2012, 06:15 AM
03_Denali's Avatar
I have that Voodoo in my LQ4 and you will love the sound of it, it's a hard lope. I was running it with a 3200 stall with a supercharger...
5.3Okasai
03-09-2022 01:07 PM
TXsilverado
11-26-2015 10:54 AM
vmaxpro
07-27-2015 10:45 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: CAM choice: TSP 228R or Lunati Voodoo?
