Building a 408, need opinions on setup
Old Apr 2, 2008 | 10:20 PM
  #21
Klive's Avatar
Banned
HKE in Houston, built the fastest LS1 and LT1 in the WORLD... both with eagle crank and rods. Not to mention David Wolfe fastest Drag Radial car in the world, Eagle internals also.
Old Apr 2, 2008 | 10:36 PM
  #22
BLACK-SS's Avatar
speaking of arguements about the most useless posts on the internet ever
oh and i read it on the internet it must be true.
Old Apr 2, 2008 | 11:24 PM
  #23
jasond26's Avatar
I don't think it is a question of the strenght of eagle products, I personally ran eagle h beam rods for about 30,000 high boost supercharged miles without any problems. I think the eagle products require more machine work to get them into specs. An eagle crank will hold up to whatever you throw at it, thier products just require a little more work by the machine shop to balance the rotating assembly.
Old Apr 3, 2008 | 05:27 PM
  #24
chris04's Avatar
ive never heard anything bad about eagle products anyway, so until i do im not gona talk about them, just my opinion, im probably gona end up with an eagle crank or either callies, i think both brands are good
Old Apr 3, 2008 | 06:55 PM
  #25
jakebdb56's Avatar
Hey Derek, don't you run into issues when milling the 317's too much? I can't find the thread from what I'm referring to. Anyways, sounds like a good build and don't be afraid to use Eagle's products either.
Old Apr 3, 2008 | 08:12 PM
  #26
adam1803's Avatar
Originally Posted by Klive
that is EASILY the worst information ever posted on any internet forum EVER. Eagle has powered some of the quickest/fastest LSX cars to EVER be assembled. Fereday was the first LSX in the 7s and was running a 3 year old Eagle internal'd motor. Eagle is good ****, its more about choosing a builder that's worth a **** and can build what you need.
+1, bad information. Just because you (black-ss) don't run Eagle products doesn't give you the right to bash them. A ton of guys use Eagle internals and they have no higher failure rate then any other company out there.
Old Apr 9, 2008 | 11:05 PM
  #27
DubDuece's Avatar
lol, I love this forum especially when someone is getting owned....
Old Apr 9, 2008 | 11:20 PM
  #28
Derek @ EDO's Avatar
FormerVendor
Yep, you can run into issues.
You can easily mill them 30 thousandths without running into any issues.
around .007 milled = 1cc
One cc should change your compression ratio around .9 of a point in compression.
Old Apr 10, 2008 | 10:35 AM
  #29
krambo's Avatar
I am building a 1000HP 408 using Eagle internals (crank and H beams). I didn't think twice about using them. All IMHO of course
Old Apr 10, 2008 | 10:39 AM
  #30
Y2KLimited's Avatar
2500ZL1
Jan 25, 2016 06:30 AM
urdone
Aug 18, 2015 12:17 PM
USMCvet0311
Aug 14, 2015 10:28 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
