Building a 408, need opinions on setup
Old Mar 31, 2008 | 07:53 PM
chris04's Avatar
Default Building a 408, need opinions on setup
ok guys, i got me a bare 6.0 block, i plan on building it to a 408 and i want everything to be strong because i plan on spraying it. ocourse im going with forged pistons and rods along with the 4.000" crank. so theres alot of different brands ive been seeing such as eagle, manley, diamond, arias,mahle,compstar etc. so what do yall recommend me going with, and also what heads, i was thinking 243's but wasn't sure if i could with flat tops due to too much compression, so all input appreciated.also do plan on boring it .030 over thanks
-chris
Old Mar 31, 2008 | 08:38 PM
BLACK-SS's Avatar
stay away from eagle if your going to spend the money on a built motor they are on the bottom end of the spectrum. if you want this motor to be reliable i would use either a callies or cola forged crank manly forged rods and either manly or diamond forged pistons. spend a few extra bucks for the rotating assembly you wont be sorry. i have a 6.9 iron block in my truck with a callies 4" crank and manly rods and pistons along with a set of ported polished ls7 heads that were shifted for a 4" bore. the trick flow 225cc heads make the most power and torque numbers of any head on the market rite off the shelf but for a little less money ported ls6 heads are a close second.
Old Mar 31, 2008 | 08:44 PM
chris04's Avatar
thanks for the input man, keepem coming guys
Old Mar 31, 2008 | 08:46 PM
gao8302's Avatar
What is your desired CR? You have to figure that out and go from there. I would just get yourself a complete rotating assembley.
Old Mar 31, 2008 | 08:55 PM
Derek @ EDO's Avatar
FormerVendor
Nothing wrong with Eagle, tons of guys use Eagle products.
I will tell you this. It might be cheaper for you to buy the engine already built.
check out TSP.
http://texas-speed.com/shop/item.asp?itemid=46&catid=28
Factor how much it would cost you to build the motor, dont forget the machine work price. Please dont think you can just bore the block and toss the internals in.
You really should line hone, deck, use torque plates etc. etc. etc.
you can easily spend 700.00 just on machine work.
If your going to build a motor do it right, dont half *** it.
Compstar rods are great for the money! They are a little bit more expensive than Eagle but they are lighter and come ready to install right of the box.
Off the shelf Diamond pistons will probably do the job as well.
How much power do you want to make? How big of shot?
Derek
chris04's Avatar
i figured around 10.6, i didn't want too much tho because i will be spraying, i heard that the 243's would bring my compression up so thats why i was trying to figure out if i should go with dished pistons and then 243's or with flat tops and stock 317's, i have looked at the complete rotating assembley just trying to get some opinions on brands
Old Mar 31, 2008 | 08:57 PM
FormerVendor
BTW, Nitrous loves compression!
Old Mar 31, 2008 | 09:03 PM
jasond26's Avatar
Well compstar (callies sister company) makes a complete rotating assembly called the speed pack. Comes with acl bearings, compstar rods, compstar crank, and mahle pistons and rings. That is what I got for my engine, comes computer balanced with your choice of compresion. I subsituted mahle pistons for diamond custom race pistons but that is because of the lower compression I wanted. I would give compstar a call, price is comparable to eagle and the quality is better in my opinion.
Old Mar 31, 2008 | 09:05 PM
chris04's Avatar
check out TSP.
You really should line bore, deck, use torque plates etc. etc. etc.
Derek
wow, thats not bad, i was actuall figuring around $3000 on the build, i got my block for $200 bucks from my buddy it needs new bearings and its a lq4, and yes i do want it done right no doubt, and i fugured around 500 to 700 bucks on machine work, there is a local engine shop that is real good, so i figured aorund 450 rwhp, and i plan on spraying anywhere from a 75 to 150 shot. what you think...
Old Mar 31, 2008 | 09:09 PM
chris04's Avatar
really i though it wasn't good to spray with alot of compression, learn something new everyday lol, so what compression would you recommend with this motor.
