Build Around Swirl Port Heads!
Old Jul 1, 2007 | 01:44 PM
  #21
YenkoST's Avatar
I know the cam in the L98 is .410 but I can't remember what those springs are rated too. If you are going with a cam, you need to put the springs on those heads that the camshaft company recommends.
With your TBI engine, I would recommend a 212/218.
Old Jul 1, 2007 | 02:17 PM
  #22
Savage Sierra's Avatar
Question What is the compression on the LO5 Vin K 350's?
Anyone know what the actual compression ratio is on a 1995 CK1500, LO5, 5.7 TBI Vin Code K motor? If Its 9.3:1 now and I drop on 58cc heads man that would really spike the compression unless I stacked the head gaskets.
Old Jul 1, 2007 | 08:21 PM
  #23
YenkoST's Avatar
http://render2.snapfish.com/render2/.../of=50,590,323
Its 8.3:1 on a light duty engine....on a heavy duty engine its 9.3:1. Your swirl port cyl. heads are 76cc stock is what most people have gotten...I have a set...just never cc'ed them. And your pistons are a dish piston with 4 valve reliefs. I can take pics of those if you want some. So, you should have a light duty engine can then with those 58cc, it should put you about 10:1.
Old Jul 2, 2007 | 09:13 AM
  #24
If it wouldn't be any trouble, I'd kinda like to see some pics. I've never had a TBI motor apart before.
I think 10:1 would be pretty good with the right cam and intake.
Thanks again.
Old Jul 2, 2007 | 02:52 PM
  #25
YenkoST's Avatar
Its the same as any other 350 apart but I'll get you some. PM me your email address and I'll send you some tonight.
Old Jul 2, 2007 | 11:36 PM
  #26
I found some on the net, thanks anyway..
Silveradorst07
Dec 31, 2015 12:04 AM
USMCvet0311
Aug 14, 2015 10:28 PM
bbowerman
Jul 26, 2015 10:57 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
