Build Around Swirl Port Heads!
To answer your question, yes you can make more power than stock by adding mods. I've gotten some decent results from working with TBI trucks. I wouldn't expect anything big power wise, but a mild improvement is easily done. The diffeerence is going to be adding maybe 20-25hp with just a cam change or 50-75 hp from a cam and head swap.
BTW, L98 heads from a Camaro are cast iron. It's the L98 Corvette heads that are aluminum and 58cc chamber.
Originally Posted by maikell77
I guess I just need to find your head porting guy.
Chevy L98 Alum 163cc Intake runner/- 1.940/1.500 valves 58 comb. chamber no pipe
120/100-83.3% @.200
163/129-79.1% @.300
189/148-78.3% @.400
199/164-82.4% @.500
199/167-83.9% @.600
Chevy L98 Ported ET Performance Alum 184/- 2.000/1.550 no pipe
129/104-80.6% @.200
187/146-78.1% @.300
228/175-76.8% @.400
242/188-77.7% @.500
247/193-78.1% @.600
Chevy Vortec L31 Iron 170/61 1.940/1.500 64cc with Pipe on exhaust
70/49-70.0% @.100
139/105-75.5% @.200
190/137-72.1% @.300
227/151-66.5% @.400
239/160-66.9% @.500
229/162-70.7% @.600
All flow numbers from http://users.erols.com/srweiss/tablehdc.htm#Chevy
Originally Posted by YenkoST
Yea, heads from a 87-92 camaro would work. If you get the L98 heads, its nothing more then the heads they use on the zz4s. However, they usually sell those for about $150 or so. They are also aluminium, flow decent, and have 58cc combustion chambers so you compression would go from 8.3:1 to 10:1 roughly. Pre-87 and you have a different bolt pattern which would mean different intake.
Aren't the heads your discribing LT1 heads? Aren't LT1 engines reverse flow coolant engines? I didn't think the reverse flow stuff was compatable? However I really don't know the much about it?
L98 heads flow surprising well...just under vortec heads. With vortec heads, once you pass .475 of lift, you will need to rework them with screw in studs from the press-in studs. The stock vortec springs are good too .450 lift. However, you will need the vortec manifold as well. So, your looking about $900 for the vortec conversion when you can get a Edelbrock TBI manifold for $240 and a set of L98 heads for $200 lets see and then with the other 460 bucks.....ported and polished, springs to match the cam, etc and bam...you have more power than vortec heads will supply. LPE has them flowing up there with the old AFR 180cc heads. So, it can be done but just find a good porter for the heads.
My concern is that they are reverse coolant flow and my truck isn't?
Also where can I find the L98's for $200?
Originally Posted by Savage Sierra
I appreciate everyones input, but so far YenkoST is the only one who remembers my $$$ flow restrictions. I can't afford Vortec heads that max out at .450 lift and the other brand are crazy expensive. The L98 would work within my budget.
The main reason the vortecs are so popular is that the flow is generated, with a relatively small port volume. What this does is keeps the bottom end numbers from sliding. When you hog out the ports, yes they flow better up top but you sacrifice air speed at low rpms. So with that in mind if you want the ultimate power, and don't mind having to add a tourque conver, the L98's work great. Just be carefull with the amount of porting you do. As I've said earlier, I built an 11:1 stroker using completely stock heads. The limiting factor was the cam, not the flow. Stock anything head with the right bottom end and cam are good to 400ish hp, alot better than the 210hp stock. The other consideration is the tbi itself, if your head flow great and you run a stock tbi or even the bigger one you still can only flow 670cfm. All I'm really getting at is head flow numbers and cam size are like pissing distance, yeah its nice but its not everything.
Thanks for the info, very helpfull, if I can find some L98 on the cheap I'll get um if not I'll build around the swirlies for now.
OK, thanks for the advise. I think I may have found a bone yard with some L98 Corvette heads, $100 bucks each if I pull um! I'll probably go that route since there so cheap. I just wander what the max lift is on the stock springs?
http://render2.snapfish.com/render2/.../of=50,590,441
