Broken Tensioner
Old Aug 30, 2010 | 05:58 AM
supercharged680's Avatar
Angry Broken Tensioner
i had a feeling haha
Uploaded with ImageShack.us
what should i do now i called the workshop told them to stop working on it.. i have the LS2 style wedge tensioner but he mechanic told me the chain is looser than having the same one installed..
Old Aug 30, 2010 | 06:39 AM
iamkeniff's Avatar
looser? it stretched already? i doubt it. you're going to have a little slack. install the wedge dampener. this is why i will ALWAYS change tensioners. that thing is a POS!
Old Aug 30, 2010 | 10:13 AM
i have a set of cloyes chain and gears.. but i heard they run without a tensioner..
Old Aug 30, 2010 | 10:57 AM
1Bear's Avatar
The LS2 style unit is a guide and not a tensioner like the piece that was in your truck, so it stands to reason that the chain will be just as loose as if nothing was installed at all. The benefit of the guide is that it will extend chain life by controlling the amount of whipping the chain goes through while running. I would have the LS2 wedge shaped guide installed and not look back, as there are entirely too many failures with the factory GM tensioner in performance applications.
Old Aug 31, 2010 | 11:44 AM
Old Aug 31, 2010 | 12:52 PM
iamkeniff's Avatar
did you replace the oil pump o ring?
Old Aug 31, 2010 | 01:16 PM
yeah. there are 2 which came with the melling, i used the green one
lxcoupe
13
Nov 20, 2015 08:43 PM
gmcyukon
Oct 3, 2015 11:03 PM
Velocity1
Oct 2, 2015 08:01 AM
trevorh1
Sep 27, 2015 08:47 PM
hackrst
Sep 2, 2015 05:27 PM
