bolts
Old Apr 16, 2012 | 02:50 AM
bogues824's Avatar
Default bolts
I know all bolts are not the same in ls series engines but are they interchangeable between them. I'm trying to get connecting rod bolts for my lm7 but if I can install ls6 bolts y not... just curious that's all.
Old Apr 16, 2012 | 05:37 AM
TXSZ66AVLANCHE's Avatar
Ls6 rod bolts are the same as the 5.3 LM7....been covered many times.
Also while we are at it the LS6 uses the exact same oil pump from the factory as well, people get scammed on this all the time. Btw I have some ported ls6 pushrods if anyone wants them 300 obo
Old Apr 16, 2012 | 11:24 AM
mcfarlnd's Avatar
Un-Registered User
If you are not sure if the bolt crosses, use GMpartsdirect.com. Check the part number for the ls6 bolt part number then, check the 5.3 part number to see if they match.
Old Apr 17, 2012 | 02:33 AM
bogues824's Avatar
OK I thought that was the case just wanted to make sure but as many of you know you can't believe everything u read on the net trust me I've read a lot of posts/threads where the info were one way tickets to the scrap yard
natejk
Nov 15, 2016 08:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
