best cam for nnbs 6.0 with l92 heads??
Old Dec 10, 2012 | 09:23 PM
07blksilverado's Avatar
I don't care I jus want good power I want high 7s bad!
Old Dec 10, 2012 | 09:27 PM
06murder's Avatar
Pat g at eps get him call. Tell him what you have and wanna do
Old Dec 10, 2012 | 11:36 PM
iamkeniff's Avatar
The bigger the cam the more converter and gears you need.
My old setup went 8.0 with a 1.76 60' (full weight with 28" DRs)
6.2/4L60e, PI3600, 4:10s
Old Dec 11, 2012 | 03:46 PM
Camin00's Avatar
If it is an LQ9 block it has flat top pistons
An LQ4 has dished piston I believe -6.7cc
With the L92 heads stock gaskets and flat top pistons you looking around
10.2 to 10.3 compression
With LQ4 pistons around 9.57
It's difficult to say which cam is the best. If you want an all out dragster go big "around the one mentioned above" with a big stall
If you drive it around town and track I would say around a 224-228 intake duration with a 228-232 exhaust duration, but there much more to cams than just duration....LSA, ramp rate, lifts.
It is better to go a lil small with the cam than two large.
More info please. Stall size or future stall size, rear end ratio
The L92 heads flow pretty nice so I would recommend not spending money on cnc job and put the towards stall and gear.
A stock cam with 4.10s and 3500+ stall would scream down the track vs. ported heads with a cam on a stock stall and low 3.42s for example
Old Dec 11, 2012 | 05:20 PM
low2001gmc's Avatar
8-12 degree split for stock heads; 4-8 degree split if heads are exhaust ported or cncd;
as for duration, got to factor in truck weight, compression ratio, intended stall and gears, and of course intended goal.
i run a 228-232 with exhaust ported only heads on a daily driven truck and like it but may move up due to truck duty reduction to weekend toy only
Old Dec 11, 2012 | 08:38 PM
silverado1ss89's Avatar
Cam gear and stall will make the difference
Old Dec 12, 2012 | 08:28 AM
Ok yes its a daily driver I drive around town an to the track I got a 3200 stall with 4:10 gears the motor I thank is the L76or LY6. Thanks for all the info
Old Dec 12, 2012 | 08:32 AM
Silverado1ss89 what's your set up? If you don't mind me asking
Old Dec 12, 2012 | 08:39 AM
Jake99's Avatar
Check out the vengeance racing stage 2 ls3 cam, that would be a pretty good cam for that engine. Believe it's a 227-235 with just over 600 lift, might try and get it in a 112 lsa +4. These l92 heads have a vary large intake valve so they tend to bleed off a lot of cylinder pressure when the valves cracks open being the reason most want a smaller intake dur, unless your willing to run a 4500-5000 stall converter.
Old Dec 12, 2012 | 08:45 AM
Cam 3600 stall and 373 gears on a L76
