Bad News
Old Mar 24, 2008 | 09:03 PM
  #41
leochevy2001's Avatar
00silv4.8, you get a chance to install your cam yet?
Old Mar 24, 2008 | 09:30 PM
  #42
00Silv4.8's Avatar
I have not but I actually just sent Chris a PM today about it and were shootin for the 18th. Ordering my LTs in the next couple weeks and hopefully in before the cam, so keep ur fingers crossed and wish me luck
Old Mar 25, 2008 | 06:46 AM
  #43
will do man!
what LTs you getting?
Old Mar 27, 2008 | 09:49 AM
  #44
aaronk227's Avatar
i'm doin a cam/heads swap this weekend on my 4.8. The springs are already done on the heads so I just have to bolt them on. But what is this everyone is saying about the harmonic balancer? I am used to the older motors where we would just jam it with a breaker bar. What tool do I need to get the balancer off?
Old Mar 27, 2008 | 10:10 AM
  #45
Stoichiometric's Avatar
Some guys rent the chrysler balancer puller from the parts place. You can impact the bolt out, you should replace it with a new bolt when it goes back together because it is torque to yield. Use a piece of all thread or the correct tool to pull the balancer back on. You want the all thread to be bottomed out in the crank before you start pulling the balancer on. Get the new bolt as tight as you can.
Old Mar 27, 2008 | 10:23 AM
  #46
I used the cheap tool autozone sells for like 34 bucks, it worked good with no problems. Just had to get a longer crank bolt to pull the balancer all the way out.
Old Mar 27, 2008 | 12:59 PM
  #47
kbracing96's Avatar
If you throw the balancer in the oven at 375 for 20 min or so, it will slide right on, but you have to be quick about it, or it will only slide halfway and stick, but you can then usually pull it the rest of the way on with the stock bolt.
Old Mar 27, 2008 | 01:14 PM
  #48
JERRY2500's Avatar
14 Second Truck Club
I've done this twice and works great
Old Mar 27, 2008 | 01:25 PM
  #49
BOTLFED_AWD's Avatar
formerly lamborado (1-12-2012)
i used one of the cheap vato zone pullers and this is what happened
so dont be suprised when this happens, so i had to use a bigger one but apparently these results arent typical hahah as for putting it back on just heated it with a little 12$ torch from home depot and slid it on used the impact to put it all the way back on then hook a chain to it put the other end on a bolt somewhere on the motor and torque that bizatch down. lot easier than it sounds.
Old Apr 3, 2008 | 08:07 PM
  #50
FstFwrd's Avatar
I used the "wine bottle opener" style compressor when I did my cam swap. It did work but it was a big pain in the ***. I will be buying the proper tool before I tackle my next swap.
moregrip
Jul 26, 2016 11:21 AM
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
