arp torque specs
Old Oct 18, 2011 | 08:28 PM
bad cutt's Avatar
Default arp torque specs
I have arp rod bolts and head studs for my 5.3 I need tourqe specs for them please
Old Oct 18, 2011 | 09:15 PM
I want to say 70ftlbs on the rod bolts
I know on my lunati rods we had to use a bolt stretch gauge so the tq was a little different on each one
I know the studs you put in hand tight and do a 3 step tq on the nuts
I did 35/50/70 with arp moly lube
it may be different if you use oil instead of moly
Old Oct 18, 2011 | 09:35 PM
08cheyennesc's Avatar
ARP head stud kit
1st Pass 30 lb-ft
2nd Pass 50 lb-ft
3rd Pass 80 lb-ft
ARP intake row flange bolts
Final pass 23 lb-ft
That's according to my "how to build and modify GM ls-series engines" book, it don't have ARP torque # for rods though . Here is what it says for OEM rod bolts,
Early OEM rod bolts(pre 2000)
1st pass 15 lb-ft
2nd pass 60*
Late OEM rod bolts(post 2000)
1st pass 15 lb-ft
2nd pass 75*
LS7 OEM rod bolts (06+ titanium rods)
1st pass 15 lb-ft
2nd pass 110*
Old Oct 18, 2011 | 11:37 PM
Coban's Avatar
Ever tried ARP webpage? Google?
Old Oct 20, 2011 | 09:50 AM
Sales2@Texas-speed's Avatar
Former Vendor
ARPinstructions.com | Kit Instructions and Torque Values
Enter the item number, and it'll give you the full instructions including torque specs
SS94S10
Jan 3, 2019 01:57 PM
jscherbs
Sep 30, 2015 07:54 AM
g6t6o
Sep 26, 2015 10:57 AM
Tuckin15s
Sep 23, 2015 09:35 PM
chvy=power
Sep 8, 2015 11:06 AM
