anyone unshroud their valves?
Old Jul 24, 2012 | 07:37 AM
Gadgetized's Avatar
Default anyone unshroud their valves?
Well, I decided to see how the cylinder on a stock 6.0 bore matched my TSP PRC 2.5 truck heads. This is a pic inside the bore of a stock 6.0 cylinder looking at the bottom of the combustion chamber. Looks like I could remove quite a bit of material. Anybody done this? It also makes me think how close the intake valve was to the cylinder wall on my 5.3.
Old Jul 24, 2012 | 09:53 AM
grey matter 04's Avatar
13 Second Truck Club
yep mine was part of the performance valve job i had done
Attached Thumbnails anyone unshroud their valves?-069.jpg   anyone unshroud their valves?-072.jpg
Old Jul 24, 2012 | 10:09 AM
Gadgetized's Avatar
Did you look at it from the inside of the cylinder like in my pic? Mine was CNC'd when I bought them.
Old Jul 24, 2012 | 10:12 AM
no i didnt
Old Jul 24, 2012 | 10:50 AM
Gadgetized's Avatar
I will take a better pic tonight of the head off the block. I scribed the outline of the cylinder.
Old Jul 24, 2012 | 04:53 PM
Gadgetized's Avatar
From the side of the exhaust valve to the side of the CNC'd chamber it is .078". If I opened it up to the 4.030 bore it would be .138". The intake side would be .1575 if I opened it up to the 4.030 bore. I just think it could add a little more airflow. According to my math if I am doing it right, it would have only left .011 away from the stock 5.3 cylinder wall. I wonder if flowed on the stock 3.779 bore if the larger valve would even help.
Old Jul 24, 2012 | 05:47 PM
TXsilverado's Avatar
i did it by picking up a set of trickflow 225's. it's a little more expensiveof a method.
Old Jul 26, 2012 | 11:43 AM
Gadgetized's Avatar
I opened up the chambers to about the stock bore. I didn't finish it, just wanted it close. I will finish opening it up after the block is bored. It looked like it made quite a difference on the side of the exhaust valve.
Old Jul 26, 2012 | 03:57 PM
why not pay a machine shop to do it?
Do you have a way of measureing cc of chambers?
using a dremel doing it your self will make every cylinder a different cc combustion chamber
Old Jul 26, 2012 | 05:13 PM
Gadgetized's Avatar
Yes I can measure the CC's. Measuring CC's is not hard at all. I would rather do this work myself. There are certain things I like a machine shop to do like machining. I would rather do everything else myself.
