Anyone have bad experience with new lifters?
Old Feb 16, 2015 | 11:41 AM
  #21
69Camaro427's Avatar
Maybe try and throw some type of oil additive and pray that it clears it up haha.
What oil are you running? I run 10W30 in winter and 10W40 in summer. The 10W40 really quiets any taping/knocking I have randomly during the hot 100+ days.
Old Feb 16, 2015 | 11:44 AM
  #22
Are the oil pressure and lvls fine. After my cam swap my truck was tapping bad b/c it was burning through oil fast, so I replaced the PCV and it fixed everything.
Old Feb 16, 2015 | 11:48 AM
  #23
Beatdown Z's Avatar
Laid Back
5w-30
At this point I don't even care if it blows up. I'll find a known running engine to put in if I have to. I just need this van back on the road. It's been down way too long.
There's only three things it can be, in my opinion. Bent rod, bad piston/wristpin, or bad rod bearing. I think if I put enough miles on it, I'll find out which one it is...
Old Feb 16, 2015 | 11:50 AM
  #24
Beatdown Z's Avatar
Laid Back
Oil pressure and level are perfect.
Old Feb 16, 2015 | 01:17 PM
  #25
Beatdown Z's Avatar
Laid Back
Piston slap is a possibility too, I guess.
Old Feb 16, 2015 | 01:47 PM
  #26
Have you had a chance to let the motor warm up to see if it goes away?
Old Feb 17, 2015 | 12:33 AM
  #27
1FastBrick's Avatar
Custm2500's Rude Friend
Is this a press pin rod an pin combo?
Are the rods and pistons assembled correctly?
Old Feb 17, 2015 | 06:41 AM
  #28
Beatdown Z's Avatar
Laid Back
Yes, it's a pressed pin and rod. I'm 99% sure they're assembled correctly.
I have let it warm up and the noise is still there.
Old Feb 17, 2015 | 01:54 PM
  #29
Beatdown Z's Avatar
Laid Back
Have the pan off right now. Can you guys think of anything I can check while it's off?
Could anything fuel/ignition related cause that noise? I'm working with accessories and **** that has 220k miles on them.
Old Feb 18, 2015 | 04:45 PM
  #30
Beatdown Z's Avatar
Laid Back
LOL, ******* junk
