Anyone have bad experience with new lifters?
Old Feb 14, 2015 | 12:15 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I have some questions for you guys that have had issues with the LS7 lifters.
1. Where did you guys with issues get the lifters from?
2. Were they in bulk packaging or individual boxed?
3. Did you clean or inspect each one prior to pre lubing them for assembly?
4. Did you depress the plunger several times to push the air out when pre soaking?
Old Feb 14, 2015 | 01:12 PM
69Camaro427's Avatar
1. Ws6store
2. Individual in one large box like spark plugs
3. No nicks and all the rollers rolled well... no resistance.
4. I depressed them while submerged in oil. A lot of people don't know that trick surprisingly.
Old Feb 14, 2015 | 01:35 PM
GMCtrk's Avatar
LS7 lifters are every bit as good as stock GenIII lifters.
I think the key is to get the lifters in the 8 pack box and the boxes should say AC delco on them including the individual box for each lifter. Those LS7 lifters sold on ebay in the non-labelled white boxes may be lifters that didn't meet QC being sold at a discount.
Old Feb 14, 2015 | 03:56 PM
George C....'s Avatar
Formerly ScreamingL
LS7 lifters are same lifters in every 07+ LS motor
summit has them for around 120 bucks
Old Feb 15, 2015 | 10:00 AM
brewster240's Avatar
if its in a work van that spends its life below 3500 rpm why did you put in ls2 cam?
Old Feb 15, 2015 | 04:58 PM
Beatdown Z's Avatar
Laid Back
Well I changed the lifters and it sounds exactly the same. How many of you guys can clearly hear the sound in the video? What else could make that sound? The rod bearings, wrist pins, maybe a bent rod?
I put the LS2 cam in because I had it on the shelf, along with springs and a sensor. All I had to buy was a $40 cover. I also didn't have a LQ4 cam laying around...
Old Feb 15, 2015 | 05:02 PM
Formerly ScreamingL
are you soaking the lifters prior to install?
Old Feb 15, 2015 | 05:06 PM
Beatdown Z's Avatar
Laid Back
The first set, no. The second set were used and soaked. I couldn't even depress the plungers. Put the stock pushrods back in. It's about 1-3/4 turn preload. The valve train seems quieter than before.
Old Feb 16, 2015 | 08:30 AM
Damn sorry the lifters didn't fix it. The noise you are talking about isn't the sewing machine from the springs, its the rata tat tat in the background that moves with the engine speed correct?
Old Feb 16, 2015 | 11:34 AM
Beatdown Z's Avatar
Laid Back
Yea, that's the noise. I don't know where to go from here. I'm about to drive it and see if I can make it worse to try and help me "pinpoint" it. Lol
