Anyone have bad experience with new lifters?
Old Feb 20, 2015 | 01:20 PM
  #41
Beatdown Z's Avatar
Laid Back
That's right
Old Feb 21, 2015 | 04:04 PM
  #42
Beatdown Z's Avatar
Laid Back
You guys like these vids, right? Haha
Going to pick up a GM oil pump pickup tube o-ring. See if it makes a difference over the Fel-Pro I'm running.
Old Feb 21, 2015 | 04:09 PM
  #43
GMCtrk's Avatar
Is your oil pan aligned correctly? I had a very similar issue and it turned out the oil pan was contacting the flexplate. There's some play in how the oil pan can be bolted back on so make sure it doesn't extend beyond the plane of the engine block at the back.
Old Feb 24, 2015 | 12:46 PM
  #44
01silvy's Avatar
That kinda sounds like a rod knock to me man. A rod knock will sometimes knock at twice the engine rpm because it knocks as the crank is moving that cylinder up and then down. is it isolated to one bank/cylinder or is it on multiple cylinders?
Old Mar 4, 2015 | 07:35 AM
  #45
Beatdown Z's Avatar
Laid Back
Well, I'm officially giving up on this thing. Picked up an 80k mile 5.3 to replace it. Once I get the van back on the road, I'll tear down the 6.0 and see if I can figure out what was causing the noise.
Old Mar 9, 2015 | 07:29 PM
  #46
Beatdown Z's Avatar
Laid Back
Turns out the problem was too much piston to wall clearance. I measured it and got .004-.005", which is too much. The cylinders have some minor vertical wear marks, but nothing too bad.
Old Mar 30, 2015 | 03:49 PM
  #47
69Camaro427's Avatar
what is it supposed to be 0.002 - 0.003?
Tydriver
45
Oct 23, 2015 09:19 PM
OHsixLS3
Sep 25, 2015 04:38 PM
95RCSS
Sep 18, 2015 01:14 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
