anyone experienced in installing DOHC??
Old Aug 25, 2007 | 12:52 PM
Toomnymods's Avatar
Default anyone experienced in installing DOHC??
got a set of jim wolf cams finally for my truck but cant find a installer.. everyone keeps backing out on me..
Old Aug 25, 2007 | 04:02 PM
IMD's Avatar
IMD
Banned
dealer?
Old Aug 25, 2007 | 08:42 PM
budhayes3's Avatar
PT's Slowest Truck
I've removed, replaced, and/or re-installed a gazillion overhead cams on Toyotas, but never replaced one with a performance cam. If your engine is set up anything like the Toyota's, seems like the hardest part will be setting valve lash. The Toyota uses cam followers that sit on top of the valves and have buckets that require different size shims to adjust the valves. It can be a real tedious procedure.
Whoever does the work should definitely have the proper literature handy when the time comes...these foreign engines have little tricks that if not done properly, can lead to long dollar repairs. Such as bolting/unbolting the Toy cams in the right sequence...if this is done wrong, either the cam can crack or the head could sustain damage. There are usually tricks for the cam gears and VVT controllers (if equipped)
Oobray
Jun 13, 2022 03:38 AM
LCHEE
Oct 24, 2020 04:10 PM
pittman
Jan 19, 2016 07:06 AM
black03rcsb
Sep 1, 2015 10:17 AM
Forcefed81
Aug 26, 2015 05:32 PM
