Anybody got the "Trucker" cam?
Old Aug 21, 2005 | 09:20 AM
  #31
BigBlackAv's Avatar
Originally Posted by 02sierraz71_5.3
for everyone with problems driving in a parking lot turn up base idle air flow it will cause a cruise control effect but it will get rid of all the dieing problems when turning and using the brakes at low speeds. The cruise effect can be countered with other tables.
just thought Id throw this out there
I am having this very problem...I have had the trucker cam for a few months, but this just started after I installed the Radix...where can I learn more about what you are suggesting I do (I don't understand what you said, like how do I turn up the base idle air flow and what is a cruise control effect)...Also, Brian (Magnuson) thinks I have a vacuum leak...so that is what I'm gonna dbl check today.
Thanks for help...wierd that you would just offer up that information...I don't remember it being talked about, but I'm glad you did.
Could you also elaborate on what is causing this problem?
Thanks for the help.
Damon
Old Aug 21, 2005 | 11:30 AM
  #32
1SlowHoe's Avatar
Destroyer of Transmissions
Did you buy a NEW Radix or one from a buddy? I bought one online, used, and it was set up for the older trucks with the throttle cables. The place where the throttle cable bracket attached to the top of the Radix had 2 drilled holes to screw the bracket into. Well one of those holes goes all the way through into the intake. I couldn't for the life of me figure out why my truck was running like crap until I stuck my hand on that spot and it sucked my finger down! I put a screw in there with a little rubber gasket and the problem was solved.
Old Aug 21, 2005 | 07:59 PM
  #33
BigBlackAv's Avatar
new, in the box
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
