Any dyno charts or track times with tbss intake??
Old Feb 10, 2013 | 08:17 PM
Chevy_King1500's Avatar
Originally Posted by Camin00
I love this web site, save me tons of money from making mistakes haha
I think the largest throttle body made for the truck intake is 85mm
Is this a bad up grade for $300-400?
if you have 300-400 dollars to spend. i would get a cam. you will gain 3-4 times the power with a cam than a throttle body upgrade.
Old Feb 11, 2013 | 01:14 AM
gamble686's Avatar
Out of all the different intake manifolds options, yall are saying for N/A mild build the truck intake is the best option for the lowend power band?
Yes, not really anything cost effective out there intake manifold wise. You are better off with a decent cam and stall.
Originally Posted by Chevy_King1500
TBSS intake, you will lose power with 5.3 or 4.8 heads. and with FI, guys on here are making huge power on the stock intake and 78mm throttle body
IMO not worth the money
yes.
Would you care to explain this fully to me as several people have seen good gains when used on properly ported 5.3 heads. All of the gains coming on the top end, but fans none the less and yes they will lose bottom end most likely as I had mentioned. I agree though not worth the money.
As for the idea of FI builds making good power on the stock intake that is like saying people make good power on the stock cam or stock heads, sure they are making good power, but why have a restriction in place like that. Some have reported in pro charged setups making more power on lower boost when switching to the Nnbs intake.
Stay away from that 85mm option. You will make equal power with less headache via a stock ported tb. They sell for about $120 from a pro or you can do it yourself if your up to it for free.
Old Feb 11, 2013 | 09:26 AM
Camin00's Avatar
I did not tell yall I already installed the 210/218 .551/.551 on 116lsa (.584/.584 with 1.8 rocker ratios) with milled .03 862 heads
Love this cam for a dd mild build so much tq
I'm all about tq seeing as I hardly take my dd truck above 3000 rpm and pull a boat during the summer
I would like to run a turbo later in life making 6-8 psi I think when funds permit I will upgrade the intake along with injectors and fuel pump
For now I will keep the stock intake.
No more bolt ons I have done every possible one it seems like
I diy ported/polished my stock 75mm throttle body real even didnt notice to much other than a lil more throttle response
Old Feb 11, 2013 | 09:30 AM
Camin00's Avatar
Will have dyno #'s this summer. I got an hp tuner street/driving tune no dynos
Have to wait for the semester to be over so I can go back home to strap it on a dyno.
Changing the thread for a minute
My numbers before the cam 274rwhp and 336rwtq were on a mustang dyno
This shop moved to a new location to far away, so now the only other shop is a dynomax
Is it true dynomax read 10-15% higher than what the truck is really producing?
Old Feb 11, 2013 | 01:18 PM
gamble686's Avatar
I would say the next best thing you you would be to get your heads worked. I would bet you could get them milled and a good port&polish for under $800. If they are milled .030 and the P&P is good you could pick up good power down low and thru the whole power band.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
04450r
Jul 24, 2015 01:58 AM
Ammadien
Jul 22, 2015 08:50 PM
