918s good for what lift?
Old Aug 16, 2006 | 02:07 PM
dry_kill's Avatar
Default 918s good for what lift?
Im gunna start gathering parts for my cam swap so when i get my LQ9 come income tax time i will have everything prepared, and i see "Z06dreaming" is selling his comp 918s for 100 bucks, so i wanted to know if they would be good enough for the cam im going with, it will either be a .581/.581 or .585/.585 lift on a 112lsa, so should the 918s be good enough? thx
Old Aug 16, 2006 | 02:14 PM
ap2002's Avatar
918's are good to .600 lift, so you are good with those...
Old Aug 16, 2006 | 02:42 PM
im pretty sure the 918's are underrated from the factory and they are actually good to .625 (they did this to up the sales of their 921's and 926 series)
Old Aug 16, 2006 | 02:44 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You are wrong coil bind is at .600 lift they wont go any further.
Old Aug 16, 2006 | 02:48 PM
silver-mod-o's Avatar
Hunt&Fisherator
the 918's and 915's are both good for .600 I do believe
Old Aug 16, 2006 | 03:39 PM
bluecajun5.3's Avatar
11 Second Truck Club
Default 915 & 918 specs
CC26915-16
Manufacturer: Competition Cams
Outside Diameter (O.D.) : 1.290"/1.060"
Inside Diameter (I.D.) : .885"/.656"
Installed Pressure : 105 lbs @ 1.800"
Coil Bind : 1.085"
Max Lift : 0.625"
CC26918-16
Installed Pressure : 130 lbs @ 1.800"
Coil Bind : 1.085"
Max Lift : 0.625"
Old Aug 16, 2006 | 03:41 PM
damn i think i need to upgrade my lil cam to run with the big dawgs
Old Aug 16, 2006 | 03:42 PM
1slow01Z71's Avatar
That is odd maybe they chaged the design of them or something, I was told by USA Racing Engines in Houston about a year ago that I would have to change springs to go to a cam with over 600 lift due to coil bind. Either way they are good for 581 lift in question
Old Aug 16, 2006 | 03:47 PM
dry_kill's Avatar
Alright thx fellas
Old Aug 16, 2006 | 03:51 PM
Sport Side's Avatar
.601'' here with 918s.
