8.1l injector question
No the stock ones are fine.. Bigger injectors are needed when the stockers can't supply the fuel that the motor needs, due to blower, turbo's & nitrous. Your injectors will allow you plenty of room to grow, as far as hp goes..
I don't think a ZZ502 motor cam will woke in the 496's.. They are totally diff engines, blocks.. http://www.raylarengine.com/ has some good things for the 8.1's
ya i have seen the raylar stuff but they are sky high on their prices....their stuff is all made to work together basically no need to do their cam if you aren't putting theur heads on to.
I am pretty sure a ZZ502 cam will work, you'll just need to swap some low tension coil wires and some injector wires.
The 8.1 is just a tall deck block.
496 = 4.250" x 4.37" (2001 Vortec 8100, 8.1 liter)
502 = 4.466" x 4.00"
peace
Hog
peace
Hog
GrooveCityZ71
Aug 31, 2015 12:05 PM
Raylar Engineering
Aug 26, 2015 10:36 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
