700whp in a 6.0L- what is needed
hey guys im gonna start saving up for a 6.0L/4l80e swap into the blazer- i was wondering what is needed internally for a 6.0L to handle 700whp of boost
- got a couple ideas im playing around with
Minimum in my mind would be "boost" pistons, "boost" rings, rods, rod bolts, main studs, head studs.
I would personally buy a crank too, for safety (e.g.don't need to pull the motor again kind of safety)
i was thinking- JE 8.5:1 pistons, Boost rings, probe Rods, and scat 4340 forged steel crank, 6-bolt mains, all balanced, ARP rods bolts, ARP main studs, ARP head studs
with some ported LS6 heads, and boost cam-
where do most of yall get your parts from- im gonna build this my self and put in the blazer my self
dont have the money- its gonna be a year or two before i get everything done- i was hoping to use ls6 heads if i can get the compression down low enough with the JE pistons, 317's are off of a what? i might just do alot of work to teh stock ones.
