700whp in a 6.0L- what is needed
Old Jan 15, 2007 | 09:40 AM
8ALTNG's Avatar
Ya a scat should handle it for a while. I am running a callies crank and rods with je pistons. I got my whole lower end from SDPC. Check them out...
Old Jan 15, 2007 | 03:51 PM
badnoma's Avatar
hey whats up 02 vortech, i'm doing the same exact thing right now, but really slowly. 6 liter with boost. And i too am aiming for 700whp. let me know what ya come up with. i'm still shopping for some parts. I have too many combinations i have been thinking of, and i cant decide. like always. good luck
Old Jan 15, 2007 | 04:28 PM
TurboGibbs's Avatar
Get good rods and pistons and save your money and use the stock crank IMO.
Old Jan 15, 2007 | 05:30 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The GENIIIs already ahve 6 bolt mains if you are listing that as a mod. Also good rods come with good rod bolts already. I would use whatever piston manufacturer you go withs recommendation on rings. I too wouldnt waste my money a crank at that power level but thats just me and from what I have read. Best thing you can do to help you decide is to go over to tech and do ALOT of searching in the FI section and look at the dyno lists and see what everyone is running at the levels you are looking to achieve then go from there.
Old Jan 15, 2007 | 05:53 PM
what is the stock 6.0L crank good to? i have heard the stock LS1 crank is good to 900hp not sure if its crank or whp though
Old Jan 15, 2007 | 05:56 PM
1slow01Z71's Avatar
Same crank for all GENIIIs bascially some have a bit more cut off the counterweight for rotating assembly balance but other then that its fine.
Old Jan 15, 2007 | 06:07 PM
how far would you go on the stock 6.0L crank????? because everyone get greedy
Old Jan 15, 2007 | 06:30 PM
Revolutionary's Avatar
Its not that everyone is greedy.. you have an s10.. you are used to little kids toys.. The gen 3 engines are not cheap. I have 2 other s10's.. and the original turbo blazer btw. So you know who I am. So I know what it's all about.
2004sss proved the limits of the stock lq9 I am going to prove the limits of a head and cam lq9 with rod bolts.
My guess is probobly somewhere around 650 rwhp.. and if you put that kind of power in your blazer you are looking at mid 10's
A really wise path for you would be to get yourself a lq4 engine complete.. just do a cam and your boost plan and run it with the cam only till you reach your limit.
Alot of guys talk about making 800 hp 6.0's and very few do it.
If you are going to do it on a budget.. like I said get yourself a used lq4 put some boost to it and call it done.. once you take a ride in something like that with boost its going to greatly change your mind as to how much power you need.
BTW if you want an un molested copy of ls1 edit. For an 02 blazer. I have one I never used it I use HP tuners and Tunercat.
I will sell it to yah cheap.
Old Jan 15, 2007 | 06:59 PM
sent you a pm for the ls1edit- how fast do you think i can go with stock bottom end, cam , heads with a set-up of 13psi (60trim turbo), intercooled, Meth, 3000stall, Ford 8.8" rearend and traction?
Old Jan 15, 2007 | 07:43 PM
parish8's Avatar
single digit dreamer
he hit the limit of an lq9 on pump gas. put meth or some good fuel in there and it would have been fine.
like some of the other guys are saying, 700rwhp is just a little above the limit of many of the stock parts. put your limit down to 600rwhp and you would be fine with valve springs and head studs. spend your money and time making sure the tune is good and get a good meth meth kit.
steping up to 700rwhp and you should get some pistons, if you are doing pistons you might as well do rods.
