600hp lq9
Old Jul 21, 2015 | 09:13 PM
Mark_k's Avatar
Registered User
Default 600hp lq9
Hello, thinking of putting a lq9 out of an 05 2500 in my 07 1500. I'm looking for 600hp with a super charger on it, so about 500ish NA. What kind of price am I looking at to build the motor less super charger. Would 140k miles be to many to consider for a build candidate?
Old Jul 21, 2015 | 09:25 PM
George C....'s Avatar
Formerly ScreamingL
Lq9 never came in a 2500
To make 500 NA best have deep pockets for bad *** heads, also to make 500 NA it won't like boost
Old Jul 21, 2015 | 09:28 PM
FFDP's Avatar
You won't see 500 crank hp on a NA motor, not without spending an absurb amount of money. Think more like 350-400 motor with some mods and have the supercharger bump you to that 600hp goal.
140k miles isnt even alot, and without knowing what kind of truck you'll want to drive around it hard to just say buy this or buy that before the supercharger.
Do you want a lopey/choppy cam that won't idle for **** or do you want a nice mellow cam that will give you more mid-range and top end??
Figure with needing, headers, supercharger, maybe a camshaft, fuel pump, injectors, a tune, a built trans or a 4L80e swap because the 60e will just explode, new rear end because the stock G80 will just explode and lots of other minor bits and pieces you'll want to save up around 5-7k depending on what supercharger you buy and where.
Old Jul 21, 2015 | 09:33 PM
Mark_k's Avatar
Registered User
Looking for a good mid range and top end, with a little loping to it. I'm planning on 1 7/8 headers with 3" pipe. It will have a tune. I was planning on replacing the rear. Haven't decided what super charger, but looking like it would be about 7k for one. What 6.0 would be the 05 if not a lq9?
Old Jul 21, 2015 | 09:38 PM
Formerly ScreamingL
Also what model 07 truck? Classic or 900?
2500 motor of 05 would be lq4
Old Jul 21, 2015 | 09:40 PM
Mark_k's Avatar
Registered User
It's a 900. Is the LQ4 as strong as the LQ9?
Old Jul 21, 2015 | 09:42 PM
GREENSIERRA's Avatar
are you talking 600 crank or rwhp?
Old Jul 21, 2015 | 09:43 PM
Formerly ScreamingL
Can't use a 24x motor in a 900 truck
Old Jul 21, 2015 | 09:45 PM
Mark_k's Avatar
Registered User
Looking for rwhp. What motor can I use instead?
Old Jul 21, 2015 | 09:47 PM
Formerly ScreamingL
Need something like a LY6
