6.2 cam help
Old Feb 25, 2009 | 02:15 PM
denali-08's Avatar
Exclamation 6.2 cam help
what cam would be good for a 6.2 in a single cab
Old Feb 25, 2009 | 04:10 PM
sickREDsierra's Avatar
if you could be a little more vague we could help you
LOL how about stating goals here. do you want a small cam to DD with, are you gonna change stall converter/gears... drag race... etc?
or the search button is always a good start. do some reading. i think this has been covered a few times.
good luck
Old Feb 26, 2009 | 02:00 PM
Mark Johnson's Avatar
Rule of thumb- the bigger the better...........
Old Feb 27, 2009 | 07:58 AM
white lightning SS's Avatar
Does this have VVT? Comp is the only company I have seen making cams for the VVT set-up. It includes a cam phaser limiter. If you dont have VVT your options are endless. Depends on stall, FI, NA, gears, exhaust etc. The good news is you have the bad *** heads already on your truck!!!
Old Feb 28, 2009 | 06:23 PM
norris_83's Avatar
check out mast motorsports for a true plug and play kit... I think the Comp phase limiter just limits the advance/retard on the VVT motors turning them into normal ones.... not something I would do with these new motors though...
zo6freak
14
Oct 18, 2015 06:43 PM
Three6GMC
Aug 28, 2015 07:56 AM
06 4.8
Aug 21, 2015 11:33 PM
05GMC4.8
Aug 7, 2015 09:55 PM
rudvirus
Aug 5, 2015 08:05 PM
