6.2 cam help
if you could be a little more vague we could help you
LOL how about stating goals here. do you want a small cam to DD with, are you gonna change stall converter/gears... drag race... etc?
or the search button is always a good start. do some reading. i think this has been covered a few times.
good luck
good luck
Does this have VVT? Comp is the only company I have seen making cams for the VVT set-up. It includes a cam phaser limiter. If you dont have VVT your options are endless. Depends on stall, FI, NA, gears, exhaust etc. The good news is you have the bad *** heads already on your truck!!!
check out mast motorsports for a true plug and play kit... I think the Comp phase limiter just limits the advance/retard on the VVT motors turning them into normal ones.... not something I would do with these new motors though...
Three6GMC
Aug 28, 2015 07:56 AM
06 4.8
Aug 21, 2015 11:33 PM
05GMC4.8
Aug 7, 2015 09:55 PM
