6.0 Pistons
Old Aug 9, 2006 | 08:38 PM
sliderbkt's Avatar
Right, but it is common to get pistons made for the SBC rods with the .927 journal. The cost of the pistons is the same, and it gives you a ton more options for rods.
I went with standard rods for the larger.945 journal. I'm sure that small amount won't make any difference, but i wanted this motor strong anywhere possible.
Old Aug 9, 2006 | 08:49 PM
TurboGibbs's Avatar
I'm not sure if you just had a typo but to clarify the gen 3 rods (6.098 & 6.275) have a .945" wrist pin and the gen1&2 (since 1955) SBC have a .927" wrist pin. The 6.125 rod is an aftermarket gen 1 rod that uses the old style .927 wrist pin. You can get pistons made to fit just about any combo but just cost more. Hell, you could probably put a briggs and stratton rod in a sbc.
And you could hone a sbc rod out to the .945 pin or re-bush a gen3 rod to use a .927 pin. The .027" difference in pin height would need to be accounted for as far as compression changes or have the pin height moved in the piston. Ok, i'll quit rambling now.
Old Aug 9, 2006 | 09:00 PM
dirt track racer 81's Avatar
looks like im stickin with the stock rods and pistons for now till i get the $$$$$ to build it
Old Aug 9, 2006 | 09:08 PM
how much can the stock pistons and rods hold? rpm?
Old Aug 9, 2006 | 09:12 PM
TurboGibbs's Avatar
Many guys spinning them to 6500+. I wouldn't want to turn it above 6000 on a regular basis without rod bolts but that is just a gut feeling I have for reliability.
Old Aug 9, 2006 | 09:17 PM
since its gonna be easy to work on im puttin rod bolts on, debating on puttin some 241 heads on since im getting them really really cheap..the cam in sig and heads for $150..and 918's
Old Aug 9, 2006 | 09:18 PM
ima circle track go so i love high rpms..by the way..
Old Aug 9, 2006 | 09:53 PM
ok would these work? http://texas-speed.com/shop/item.asp...d=109&catid=38
choose the 4.00 bore and stock 6.098 rod?
Old Aug 9, 2006 | 10:29 PM
RoninsDenali's Avatar
I think you got a winner there
And for what its worth, about spinning the engine too fast, the LS2/LQ9 share the same rods, use the same rod bolts. 6500 rpm redline is defiently within reason, assuming good quality valvesprings
I spun my stock LQ4 up to about 6700rpm's a few times. But, one of the piston wrist pins siezed (evil pressed pins), and beat things up a bit, but i dont know whether that was a result of my oil pressure problem, or a result of overrevving.
Old Aug 9, 2006 | 10:48 PM
TurboGibbs's Avatar
Those would give you 9.9:1 with 317 (6.0 71cc) heads and 11:1 with 4.8/5.3 (61cc) heads.
