6.0 build
Old Jul 22, 2012 | 06:44 PM
heavyhitter5.3's Avatar
Default 6.0 build
i have a 04 with a 5.3 going to swap to a 6.0 lq4 what do i need to do to get 450hp
it has the 317 heads on it. any help new to this lol
Old Jul 22, 2012 | 06:51 PM
ltr450ryder's Avatar
Boost!
Old Jul 22, 2012 | 07:53 PM
2doorfury's Avatar
with a n/a set up...243 heads port/polish and milled. 8.1 injectors, fast intake w/ big TB and a good tune and i bet you'd be there.
Old Jul 22, 2012 | 08:01 PM
2doorfury's Avatar
turbo would be the cheaper route tho..3500 for a complete turbo kit w/ injectors and you could probably do over 500hp.
Old Jul 22, 2012 | 08:58 PM
mhotrodscooter's Avatar
My setup plus a 50 shot and good cam that will match your topend and a good exhaust system will get you there
Old Aug 8, 2012 | 09:56 PM
Chevy_freak's Avatar
Id just boost the 5.3 and run it till it blows up. In the meantime do lots of reading and research and figure out what you want to achieve with the 6.0 (since 450 will get old and youll keep wanting to upgrade).
Old Aug 8, 2012 | 10:22 PM
N/ALS1's Avatar
This setup will net 450 to the wheels or will it be the crank? This is my setup but w/o the pnp 243's, 370 cid, Lt's true duals. I will be getting them port and polished soon. Thanks for the help.
Old Aug 9, 2012 | 05:51 AM
TXSZ66AVLANCHE's Avatar
450 to the wheels NA is possible, no boost needed. Port n polished 243 heads, and the correct cam.
Azim05
Aug 27, 2015 05:33 PM
spiritfish
Aug 23, 2015 09:58 PM
Abuckeye
Aug 19, 2015 06:11 PM
USMCvet0311
Aug 14, 2015 10:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
