6.0 with a bad oil pump?
Old Aug 16, 2005 | 08:26 PM
slowec's Avatar
Default 6.0 with a bad oil pump?
A friend of mine works at a caddy dealer and in general conversation says, dang I hate pulling that escalade motor . Are you for real? he says yeh why You want it? UMMMM YEAH. So whats the scoop? He says @ 8000 miles the oil pump went bad and spun some bearings . Is this common. I might have a 6.0 for free!!!
Old Aug 16, 2005 | 09:17 PM
TURBHOE's Avatar
who cares just get it. and put in a good pump
Old Aug 16, 2005 | 10:54 PM
Get the motor and pull the main caps.Then take the crank to a good machine shop and either polish or turn it depending on the damage.Then install new bearing and a ported oil pump.You should be good to go for about $400 or less.If you are planning on a cam install it while you have the motor out.
Old Aug 17, 2005 | 04:45 AM
slowec's Avatar
Yea I figure a ported oil pump, arp bolts, cam, and maybe some homebrew rubbing on the heads. I figure I might spend on the whole project what I had thought I might spend for the engine alone if I went used salvage. I am very hopefull. I have been wanting a radix , but this is a way for more power now, less money, and I can still go FI down the road. Win win situation.Any 6.0 swappers, any pointers are welcomed!
Old Aug 30, 2005 | 10:31 AM
slowec's Avatar
TTT Somebody has got to have info and advice on this. It will be mine soon.
Old Aug 30, 2005 | 02:09 PM
I don't have none right now. I'm swapping mine next thursday.
Old Aug 30, 2005 | 04:43 PM
slowec's Avatar
What all did you do to the 6.0 before the install? Cam? oil pump? arp bolts? Details, I love all the details!!!
Old Aug 31, 2005 | 04:32 AM
I put a self ported oil pump, Patriot Stage 2 heads, 232/236 cam, LQ9 pistons, ARP rod bolts, Trick Flow pushrods, LS2 timing chain, long tubes. Guess that about does it.
Old Aug 31, 2005 | 07:18 AM
slowec's Avatar
Das what I'm talkin bout!!! Congrates!!!
Old Aug 31, 2005 | 07:23 AM
I talked to Allen yesterday. He told me to email him all my mods so he can do my retune. Did that first thing this morning. I asked him, how fast did he think it could go and he said around mid 12's. If I just see a 12.99. I will be happy as a ****.
