5.3L Cam Questions.
Old Sep 15, 2009 | 02:43 PM
fbodygirl7931's Avatar
Default 5.3L Cam Questions.
I have a MS4 cam from Texas Speed. It is a 239/242, .649"/.609" with a 111 LSA. I wanna run this is a 5.3L with head work of course. I am getting the springs and retainers and everything from Texas Speed also, but wanted to know if anyone else has put this cam into a 5.3L so I know what Im getting myself into. Thanks for all the help yall.
Old Sep 15, 2009 | 04:28 PM
Tootall's Avatar
I put a MS3 in a 5.3 before, . . . but not quite as much duration/lift as the MS4
. . . it sounded good . . .
Old Sep 15, 2009 | 06:38 PM
I know its gonna sound good, but I needed to know if PTV clearance is going to be an issue with the stock 5.3L bottom end. I was told it was in the LS1 but I believe the LS1 has flat top pistons and Im pretty sure the 5.3L has dished pistons, so will i have any issues with it?
Old Sep 15, 2009 | 06:44 PM
silveradokidd_4518's Avatar
thats way too much cam for a 5.3...
Old Sep 15, 2009 | 07:02 PM
Mangled03gmc's Avatar
Baltimore Whore
If it has worked in a ls1 it should work in the 5.3. 5.3's have flat tops also, the 4.8's are the dished ones, the deck heights are the same as a ls1 IIRC... It will just be a bit of a pig to tune, unless your running a huge verter..
Old Sep 15, 2009 | 07:04 PM
00ChevyScott's Avatar
Wearin' da big hat
wrong john, the 5.3 has dished pistons, 4.8 has flat.
noob
Old Sep 15, 2009 | 07:06 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
noob
He's right John. The 4.8 and the 5.3 L33 share flat top pistons.
Old Sep 15, 2009 | 07:08 PM
Baltimore Whore
UHHH HAAA, you know what I thought about for a min after I posted it, got it f^&Kd up, bass ackwards... My bad
Old Sep 15, 2009 | 07:13 PM
LS1FREEK's Avatar
13 Second Truck Club
Yea LM7 5.3's 2006 and older all have dished... right? Cuz then there should be no clearance problems...
Old Sep 15, 2009 | 08:27 PM
Tootall's Avatar
I'm pretty sure that it'll work . . . but what are your goals for this setup? The power band for this cam is 3400 - 7200 . . . you're going to need more than good heads to run it . . . built trans, big stall, 4.10, better than stock truck intake, bigger injectors . . . the list goes on
