5.3L Cam Questions.
Old Sep 15, 2009 | 09:36 PM
  #21
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by matthew_kirby_07
I got a 06 5.3 in a crew cab and i wanna put a z06 cam in it but i've been told that the cam journals are different sizes in a ls series than a 5.3 has anybody done this and will it work?!?!
It would be better if you first introduce your self in the new members sections... Yes the z06 cam has been done, no prob...
Old Sep 15, 2009 | 09:43 PM
  #22
matthew_kirby_07's Avatar
Registered User
i did man thanks! will any ls series cam work in there?
Old Sep 15, 2009 | 09:50 PM
  #23
Tootall's Avatar
yes . . . but read up on the L92 or LS3 stuff . . . and the cam sensor is up front
Old Sep 15, 2009 | 10:07 PM
  #24
Registered User
is that the way it is in the late model 5.3?
Old Sep 15, 2009 | 10:10 PM
  #25
fbodygirl7931's Avatar
The only difference between an LS1 and any 5.3L from 99 up (i believe thats the right year) Is the piston bore size. they use the same crank, and piston rods. The piston bore size is the ONLY difference in the internals. And of course the 5.3L is a cast block (most of the time)
Old Sep 15, 2009 | 10:12 PM
  #26
The LS3 is a different motor. I believe the only thing you can run on a LS1, LS2, ect is the heads ASLONG as you run the intake with it also. But that combo is suppost to make some good numbers.
Old Sep 15, 2009 | 10:15 PM
  #27
Registered User
i've herd from a few diff people that the 5.3 heads will flow better than ls1 heads but i haven't saw the number! Anybody got a z06 cam for my truck?!?!
Old Sep 15, 2009 | 10:29 PM
  #28
They do flow a little better. The 5.3l heads on an LS1 is a common upgrade to make a little more power, and if your gonna get a Z06 cam TURBO it. They LOVE turbos. Its like PB&J they just go together.
Old Sep 15, 2009 | 10:50 PM
  #29
Registered User
i need to do something it wont get out of its own way lol!
Old Sep 15, 2009 | 11:13 PM
  #30
A Z06 cam is an awesome cam for an upgrade on a 5.3L. What kinda performance are you going for? Do you wanna be heard, like a lope or something like that or do you want it to be smooth but make power like a sleeper?
