5.3L with 4.8L pistons Compression??
Old Nov 10, 2014 | 10:18 AM
zaathur151's Avatar
Default 5.3L with 4.8L pistons Compression??
Can't seem to find this info anywhere wondering if i put 4.8L flat top pistons on a stock 5.3L with stock 706 heads what would my compression be at?
Old Nov 10, 2014 | 10:55 AM
Hubcap's Avatar
I think it will be around 10.5:1 somewhere in there. It will make a difference. I think mine I have ported 706 heads milled .20 and its snappy but will be doing flat top 4.8 pistons on the extra block I got.
Old Nov 10, 2014 | 03:40 PM
ltr450ryder's Avatar
10.3:1ish on unmilled 706 heads
Old Nov 10, 2014 | 03:54 PM
zaathur151's Avatar
thanks
Old Nov 10, 2014 | 05:54 PM
69Camaro427's Avatar
Yea 10.3 to 10.4 range is what I'm getting with stock 0.051 gaskets and unmilled heads.
10.7 with 0.04 gaskets with unmilled heads
I use this
Engine Size and Compression Calculator
Roughly every 0.007 milled = 1cc removed so 0.028 milled would remove 4cc
706 heads are 61.15 cc
bore is 3.77 for 323ci and 3.78 for nbs 325ci
stroke is 3.62
Old Nov 11, 2014 | 12:40 PM
zaathur151's Avatar
Have another question the factory 5.3L dish piston done size (cc)?
Old Nov 11, 2014 | 01:53 PM
-7ish
Old Nov 11, 2014 | 01:54 PM
I don't know the exact dish, but its around -7cc
4.8 flat tops are 0cc b/c they are flat lol
Old Nov 11, 2014 | 02:26 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The dish is -8cc as Agearhead4life physically measured them.
Pistons on an LS engine are usually out of the hole around +.005 or so. Every block is different so its important to measure.
zblee
Nov 11, 2015 12:41 AM
bisqikss
Sep 8, 2015 03:35 AM
