5.3L with 4.8L pistons Compression??
I think it will be around 10.5:1 somewhere in there. It will make a difference. I think mine I have ported 706 heads milled .20 and its snappy but will be doing flat top 4.8 pistons on the extra block I got.
Yea 10.3 to 10.4 range is what I'm getting with stock 0.051 gaskets and unmilled heads.
10.7 with 0.04 gaskets with unmilled heads
I use this
Engine Size and Compression Calculator
Roughly every 0.007 milled = 1cc removed so 0.028 milled would remove 4cc
706 heads are 61.15 cc
bore is 3.77 for 323ci and 3.78 for nbs 325ci
stroke is 3.62
I use this
stroke is 3.62
The dish is -8cc as Agearhead4life physically measured them.
Pistons on an LS engine are usually out of the hole around +.005 or so. Every block is different so its important to measure.
zblee
Nov 11, 2015 12:41 AM
