5.3 pcv ?
Old Feb 26, 2010 | 05:43 PM
Big Port Jimmy 6's Avatar
Default 5.3 pcv ?
Do the 5.3s have the oil in intake problems that the ls1s have? Would the ls6 valley pan mod be beneficial or just run a catch can? Jay
Old Feb 26, 2010 | 06:11 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, all of the GENIII's do...I run a catch can myself, but have heard good things about the LS6 valley cover conversion...that's the cleaner way to do it.
Old Feb 26, 2010 | 08:36 PM
TIM Z's Avatar
11 sec. Truck Mod
Can someone here elaborate on the oil problems ? Thanks.
Old Feb 26, 2010 | 08:51 PM
budhayes3's Avatar
PT's Slowest Truck
The GENIII engines consume an excessive amount of oil through the PCV system, GM re-designed the PCV valve, but it doesn't work. I heard that they re-designed the baffles in the valve covers but I'm not sure if they're available yet, or if they work.
Old Feb 26, 2010 | 09:09 PM
skolman91's Avatar
isnt the pcv valve a fixed orfice type and in the valve cover? asking cause thats what i thought id heard somewhere and not sure..
Old Feb 26, 2010 | 09:14 PM
Yes if yours has the new one in it. The ls6 mod draws from the valley pan and not right by the rockers that need oil. Jay
Old Feb 26, 2010 | 09:21 PM
eallanboggs's Avatar
They went to what they call "fixed venturi" PCV which if you thing about the way the PCV system is designed to work the PCV valve can NOT be fixed. It needs to be variable and two way to work properly. If they put extra baffles in there I guess that would turn the area under Bank 1 rocker cover into a big catch can of sorts. I went to Harbor Freight and got a OIL/WATER separator for an air compressor for $8 and two hose barbs at $2 each. An other $2 for 3 feet of 3/8" hose and you've got a catch can for under $20. After seeing what you find in your catch can you'll wish you had one on there from day one. In areas of high humidity you'll also find water in your catch can(or water and oil mixed-MILKY) which is the result of condensation in your oil pan after the engine goes through cold soak.
Old Feb 26, 2010 | 09:22 PM
skolman91's Avatar
you mean the new valve? when did that come out? and has it always been in that spot(in the cover) for ls motors besides the valley cover spot for ls6's..?
Old Feb 26, 2010 | 09:42 PM
1Bear's Avatar
I believe what he ment was you have new valve if you have the newer style fixed orifice style PCV. If I recall correctly, they started using them in '04 and the PCV has always been in the same location on the LS style truck motors.
Old Feb 26, 2010 | 09:45 PM
TIM Z's Avatar
11 sec. Truck Mod
Pics would be cool of your setup!
