5.3 Engine Indentification Help!!!
Old Aug 27, 2010 | 05:42 PM
Tshearman's Avatar
Default 5.3 Engine Indentification Help!!!
Hey guys Im going to look at a 5.3 I found on craigslist either tonight or tomorrow. Problem is I dont know how to identify that its a 5.3 and not a 4.8. What do I need to look for?
Old Aug 27, 2010 | 05:45 PM
viciousknid's Avatar
Where's the Beef?
https://www.performancetrucks.net/fo...hlight=pistons
To add. IIRC 4.8 should have flat top pistons and 5.3 has dished. 4.8 has higher compression because of this.
Old Aug 27, 2010 | 05:52 PM
Tshearman's Avatar
Thanks but I could use some more info on the "inscription on the bottom right hand side of the block" Is this going to flat out say 5.3? I cant check the bore or stroke or anything internal really b/c I want to know before I buy it. I dont think homeboy who's selling it wants me tearing his engine down
Where's the Beef?
btw. If it's an aluminum block with flat tops then it's an L33 5.3 HO
I edited my previous post for the pistons. Just pull a plug and shine a light in to look at the top of the piston.
Old Aug 27, 2010 | 07:11 PM
outlawz2004's Avatar
It will say both on it, 5.3 and 4.8.
Old Aug 27, 2010 | 07:30 PM
Tshearman's Avatar
Damn so basically the only sure fire way to check is by pulling a plug and looking down at the piston?
Old Aug 27, 2010 | 07:37 PM
dlt76028's Avatar
Yes. the block says 4.8/5.3. you have to pull a plug and see if the piston is dished or flat. dished is 5.3 and flat is 4.8.
Old Aug 28, 2010 | 03:13 PM
budhayes3's Avatar
PT's Slowest Truck
Not sure if you'll be able to see what you're looking for by just pulling a plug, as you may not be able to see the circumference of the pistons, might need a bore scope to get a good look...but as I mentioned, I"m not sure...
Old Aug 28, 2010 | 05:05 PM
Where's the Beef?
The exterior of both engines is exactly the same and even use the same heads. The only difference is the type of piston used and the stroke of the crank.
Old Aug 30, 2010 | 11:08 AM
Tshearman's Avatar
Bought the engine for $300. I tore the heads off b/c the guys put head gaskets on it and didnt replace the head bolts (and I just dont trust other people's work). Its definitely a 5.3 so Im happy with that but it had been sitting for a year + and there was slight surface rust on the sylinder walls. So Im pullin the whole thing apart and honing the cylinder walls before I put it back together.
I really appreciate the help guys!
I started a new thread with some build questions if you don't mind helping there to ----> https://www.performancetrucks.net/fo...93#post4529493
