5.3 Engine Indentification Help!!!
Hey guys Im going to look at a 5.3 I found on craigslist either tonight or tomorrow. Problem is I dont know how to identify that its a 5.3 and not a 4.8. What do I need to look for?
https://www.performancetrucks.net/fo...hlight=pistons
To add. IIRC 4.8 should have flat top pistons and 5.3 has dished. 4.8 has higher compression because of this.
Thanks but I could use some more info on the "inscription on the bottom right hand side of the block" Is this going to flat out say 5.3? I cant check the bore or stroke or anything internal really b/c I want to know before I buy it. I dont think homeboy who's selling it wants me tearing his engine down
btw. If it's an aluminum block with flat tops then it's an L33 5.3 HO
I edited my previous post for the pistons. Just pull a plug and shine a light in to look at the top of the piston.
Not sure if you'll be able to see what you're looking for by just pulling a plug, as you may not be able to see the circumference of the pistons, might need a bore scope to get a good look...but as I mentioned, I"m not sure...
Bought the engine for $300. I tore the heads off b/c the guys put head gaskets on it and didnt replace the head bolts (and I just dont trust other people's work). Its definitely a 5.3 so Im happy with that but it had been sitting for a year + and there was slight surface rust on the sylinder walls. So Im pullin the whole thing apart and honing the cylinder walls before I put it back together.
I really appreciate the help guys! I started a new thread with some build questions if you don't mind helping there to ----> https://www.performancetrucks.net/fo...93#post4529493
