5.3 cam
formerly gasjob2500hd (6/7/2012)
My Girlfriends 2004 1500 z71 with a 5.3 ate a lifter and it ruined the cam shaft too,
truck is stock other than an intake and exhaust, Im probly going to get LPP shorties while the engines apart for $250 i cant see putting the stock manifolds on
I emailed comp cams and they suggested there XR265HR cam
54-424-11 - XFI RPM High Lift Hydraulic Roller Camshafts
with 26918-16 valve springs and 7.4" push rods 7955-16
the truck will also need a custom tune.. which Im sure will be another few hundred bucks,
Im already 800 into gaskets bolts,lifters, a new Water pump, the cam springs and pushrods are another 750... my girlfriend doesnt really have that much money so this is a budget project.
so i was wondering are there any cheeper cam kits, or could i put an ls1 or ls6 cam in with no modifications (pushrods,springs,tune)
truck needs to be reliable and get good gas milage still its a daily driver not a hot rod
If not anyone know who to call for a tune? Im in the NYC area, I called corvettes of westchester and their voicemail was full...
yea I forgot to mention she definately doesnt have the money for a new converter,
what do you mean grey matter sorry Im just not understanding your post...
At the 1/4 mile drag track it gained 4 mph and 4 tenths in time
it was 4 tenths faster just by adding the cam and gained 4 mph in speed
That cam will be fine on the stock convertor
I forgot to ask was that motor making an odd scrubbing noise? Like a chiping sorta? It drove me nuts trying to figure out what it was. I have a friend with a tahoe and his is making the same fuss. His has random misfires just like mine did.
Ditch the springs comp recommends and go with LS6 springs and the low lift version of the cam.
I think it would be better if you kinda let us know what kind of budget you have in mind.
