5.3 To 5.7 With 317
Old Feb 5, 2008 | 11:10 PM
Default 5.3 To 5.7 With 317
Well I seareched and was not able to find anything.
I know plenty on here have built a 5.7 out of a 5.3
Have you had any issues or did you have to rebalance the crankshaft?
Main question is : has anybody ran 317 6.0 heads?
Would it be a good idea to run these heads?
What compresion ratio would it be using stock 317 heads and stock 5.7 pistons?
The rods and pistons will be forged.
This engine will be FI.
I would like to have 9.0 compresion.
Old Feb 6, 2008 | 09:02 AM
Richard@WCCH's Avatar
FormerVendor
You're going to end up with something around 9.7:1 cr with flat tops and 317 heads. The 317's will work nicely on a 5.7l. Our Stage 2 CNC program will get the compression ratio down to approx. 9.2:1.
You'll also want to rebalance the crank assembly when you do the swap.
Good luck on your modding project.
Richard
Old Feb 6, 2008 | 09:41 AM
Richard
Where would it be at with stock 5.7 pistons and the stock 317 heads?
Old Feb 6, 2008 | 01:47 PM
53bowtie's Avatar
i believe he just said 9.7:1 ration with stock pistons and heads....
Old Feb 6, 2008 | 03:22 PM
quicksilverado's Avatar
If you use Diamond -8.6 cc pistons and 317 heads your c.r. will be 8.8-1.
Old Feb 6, 2008 | 03:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
YOur Stage 2 CNC program will get the compression ratio down to approx. 9.2:1.
Thats how you guys built mine! Could not be happier!
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Blwn99x
Sep 11, 2015 09:27 PM
11MPG
Sep 8, 2015 04:52 AM
bisqikss
Sep 8, 2015 03:35 AM
mayko
Sep 7, 2015 12:24 PM
