The 418 is back apart
Old Feb 7, 2007 | 09:28 PM
  #41
thunder550's Avatar
High on diesel fumes
Why is that better than pullin vacuum from the intake manifold? Because it never sees positive pressure?
Old Feb 7, 2007 | 09:29 PM
  #42
Stoichiometric's Avatar
I wonder if a bevel cut on a nipple would pull a little more vacuum before the turbo? Kinda like an evac kit that you would put in a header collector.
How much power do you think the S85 would be capable of? I was thinking about going with an S88 myself, but that may be overkill for a 408.
Old Feb 7, 2007 | 09:50 PM
  #43
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
S88 has a backorder log a mile long
Thunder, its my understanding there is ALOT more vacuum there then in the manifold.
Old Feb 7, 2007 | 10:13 PM
  #44
TurboGibbs's Avatar
How I was going to do it next was use my check valve on my pcv line for pulling vacume at low boost and not allowing it to pressurize when intake is under boost. This is the what I had already.
But the next thing I was going to do is run the catch can vacume off of the turbo intake (between turbo and air filter like Cody said). Maybe even T off the exhaust so it can pull from the exhaust that is already there and the turbo intake? I'll throw my PCV line check valve in the box when I ship it out tomorrow. I won't need it anymore.
As I said before there is too much back pressure in the exhaust for the offdraft system to work there. May work good with the cut-out open? If you don't use the exhaust just take the check valve off and put a pipe cap on it. It's either 3/8 or 1/2 pipe thread, can't remember.
Old Feb 7, 2007 | 10:21 PM
  #45
kbracing96's Avatar
I think Parish did it that way didn't he? I think he got the idea from the Supra guys. I think the high flow volume combined with the vinchery (sp) affect is enough to over come the back pressure issue and create a negative pressure for the PCV system.
Old Feb 7, 2007 | 11:31 PM
  #46
TurboGibbs's Avatar
It didn't work on mine. I put a vac/pres. gauge in line and ran it up to the windshield. It would pull 1" vacume while cruising and 4.5psi @ 6psi boost
Old Feb 8, 2007 | 02:58 AM
  #47
PappyDan's Avatar
Tribe Shaman
some day i wonder if it will ever run again.
spent most of it's life in peaces.
thats all right cody, my **** is still running.
final question cody, just how much $$$$$$$$$.$$ have put in to this build now?
Old Feb 8, 2007 | 05:47 PM
  #48
1slow01Z71's Avatar
My have more money into the motor then the truck is worth, then evreything else, I dont care to total it.
Old Feb 9, 2007 | 01:08 AM
  #49
PappyDan's Avatar
Tribe Shaman
cody i will not tell you how to spend your money.
you earned it, you can spend it any way you want.
but i will ask, is it worth putting another dime in it.
Old Feb 9, 2007 | 01:30 PM
  #50
BADMOFO's Avatar
Cuz I AM a BADMOFO
For me and my piece of **** the answer to that question is NO. Besides, I can't imagine having much more fun with it than I do now....with zero down time. (I'm knocking on wood)
