408 Stroker low oil pressure (video)
Old Aug 27, 2018 | 12:41 AM
Cadillac Edd's Avatar
Default 408 Stroker low oil pressure (video)
of course another problem. OK so after a little highway race, I get to a red light and notice my oil pressure was unnormally low like 15-20 and I hear a faint lifter tap. But when I drive it will go up to 55-60 And no lifter tap. I have a mellings high volume oil pump. Only 2000 miles on everything.
Old Aug 27, 2018 | 09:19 AM
arthursc2's Avatar
Its probably the pump. Could be the pick up o ring as well.
Best way to verify its not the sender is to put a mechanical gauge on it. If its truly low, gotta take the timing cover off to check the pump and o ring.
Beyond that, mains and cam bearings dictate oil pressure in the LS motors. Someone with more experience can speak to that, I just recently learned our cam bearings were critical of oil pressure.
Old Aug 27, 2018 | 12:14 PM
darkirish63's Avatar
What's the last mod made to the engine? Any cam swap lately?
Old Aug 27, 2018 | 12:28 PM
no everything was done together
Old Aug 27, 2018 | 12:29 PM
ok im gonna take it to the builder
Old Aug 27, 2018 | 03:00 PM
Heck yeah...My stroker did this a few thousand miles into a fresh build as well - was the o-ring. Good luck...
Old Aug 28, 2018 | 01:05 PM
so I took it to the builder he says its probably the bearings also my oil pressure is even lower than what the gauge on the cluster display. Its lingering around 20-25 at idle. And sometime goes as low as 15psi
Old Aug 28, 2018 | 01:18 PM
arthursc2's Avatar
what brand bearings?
Old Aug 28, 2018 | 02:12 PM
RedXray's Avatar
100% Redneck
Cut the oil filter open and see if there is any bearing materiel inside.
Old Aug 28, 2018 | 04:43 PM
madmann26's Avatar
That's a helluva assumption.
