408 Question?
Old Oct 29, 2007 | 05:30 PM
adam1803's Avatar
Originally Posted by Low_LQ4
What about an intake setup should I get the TPIS LS6 intake or run a carbstyle intake?
One of my friends has a CNC shop and can hook me up with a sheetmetal one that will fit truck engines without any issues. What do you guys think?
That depends on how high you want to rev it and where in the rpm band you want to make the power.
Old Oct 29, 2007 | 05:52 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Some thing that would work for a DD, Also for weekend track night.
Thanks
Old Oct 30, 2007 | 09:51 AM
adam1803's Avatar
well basically the easiest thing to do would be use your truck intake. It will make good power down low but you won't be able to rev it very high. I think about 6k is the limit on a truck intake, give or take a few hundred rpms. If you go FI with it the intake won't be as big of a restriction as it would be on an N/A motor.
If you want a few more rpms out of it you could go with an LS6 intake, but you'd have to do the conversion to a car intake which is a bit of a PITA. Im using an LS6 intake right now and im happy with it for the most part, but it is holding back a bit of power compared to a 90/90 setup.
A 90/90 would be just about the best option for N/A, but alot of people don't like to use them for boosted apps.
Then you've got the Victor Jr. intake, which also requires a bit of work to make it fit and the money can add up quick for all the parts you need.
Old Oct 31, 2007 | 09:04 PM
Low_LSX's Avatar
Also what size injectors are you guys running with your 408 setups?
Old Nov 2, 2007 | 12:44 AM
Spoolin's Avatar
GFYS and STFU
Quik was running 42/48's on his NA 408 and he said the duty cycle was somewhere around 76 percent
Old Nov 2, 2007 | 01:14 AM
thunder550's Avatar
High on diesel fumes
I'm running 96#ers, and at 10psi at 5700 RPM I'm at 56% duty cycle at 10.2:1 AFR, lol.
Old Nov 2, 2007 | 01:27 AM
Quik's Avatar
5 year bitches!
for a NA 408 svo 42s are what you want. they spec out to be 48# injectors with our fuel psi. they are ideal and can be had for good prices of 250 used
and thats 76% duty cycle at 7k
Old Nov 3, 2007 | 10:55 AM
blown3qtr's Avatar
That cam oughta work fine. I'm runnin a 234/238 .598/.605 115+3 on my daily driver.
Old Nov 5, 2007 | 07:24 PM
Low_LSX's Avatar
It's working good, I need to get a bigger stall.
andrewlong
Nov 9, 2016 09:38 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
11MPG
Sep 10, 2015 08:34 PM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
