4.Great cam?
Old Apr 14, 2021 | 10:44 PM
baddbradd's Avatar
Default 4.Great cam?
I've read till I'm blue in the face and still have MORE research to do. 4.8 2012 crew cab 2wd....headers and 3:90 gears(4:10 should be minimum). Daily Driver. Need more 'ump' till I do a 6.0. 4.8 does have 243 heads
Cam recommendations with killing the tiny bottom end I have now.....
Old Apr 14, 2021 | 10:58 PM
FFDP's Avatar
Stick with a 212/218 or slightly smaller, that will work great with the engine you have and won't need a higher stall converter. Get good valve springs and you'll be able to spin that little motor to 6,200-6,400rpm easy.
Old Apr 14, 2021 | 11:19 PM
baddbradd's Avatar
Thank you, springs will be installed at the same time too. I:ll run the 'high lift', version of whatever cam.
Old Apr 15, 2021 | 06:46 AM
68Formula's Avatar
If you want to get more more power without losing more bottom end with a small displacement, get the latest version of the BTR Truck Torque Cam p/n30202111R1 (202/202 111+1). Even in a 4.8L you shouldn't feel any bottom end loss, but it'll carry up to 6k. Will work great with long tube headers.
dantheman1540
16
Oct 24, 2018 05:52 PM
sand man
May 25, 2012 06:15 PM
mots
46
Apr 2, 2011 09:56 PM
JGKadell
20
Jan 25, 2011 07:52 PM
1badgmc
Jul 14, 2006 12:05 PM
