4.8l head bolts Help
Old Aug 17, 2016 | 09:37 AM
Cyphertech's Avatar
Registered User
Default 4.8l head bolts Help
Hello first time post long time lurker. Im swaping over my heads in my truck do to the castech head issue GM had in my 05 silverado. I got a set of 862 heads to bolt on to my motor. everything is going well however i got one question for the guru's. my new reman heads have a deeper front and rear centre bolt pocket for the first bolt design (2 different legths of 11mm bolts) I ordered the bolts according to my trucks year all the same length. they went in fine and I torqued them up already. should I take them out and get new shorter bolts for those holes? will this effect anything? thanks for the help.
Old Aug 18, 2016 | 08:39 PM
Cyphertech's Avatar
Registered User
Anyone?
Old Aug 18, 2016 | 09:43 PM
Feed's Avatar
I did a quick search, difference is in the blocks not the heads. So you should have the correct bolts.
crashmymax
Mar 26, 2016 08:37 PM
07NBSChevy
Mar 16, 2016 05:41 PM
DV8
Jan 16, 2002 12:44 AM
Trevor @ Texas Speed & Perf.
Jan 2, 2002 02:56 PM
