reman engine, flexplate?
Old Mar 24, 2016 | 02:13 PM
crashmymax's Avatar
Default reman engine, flexplate?
The tuner melted a piston on my 09 5.3 after I added a trick stage 2 turbo kit. I am getting ready to install the reman and I am not sure how to attach the flexplate. The reman did not come with a new one. Is the flexplate balanced to the engine? Do I install it the way it came off the old engine? Not really sure what to do hear its holding up progress. Thanks for any help
Old Mar 26, 2016 | 12:20 AM
1FastBrick's Avatar
Custm2500's Rude Friend
These engines are internally balanced.
Old Mar 26, 2016 | 11:28 AM
Mine have always had a dowel to position them a certain way and to act as a hold. But position actually doesn't matter due to the above statement.
Old Mar 26, 2016 | 02:48 PM
crashmymax's Avatar
Ok thanks guys. The manual says to mark the flexplate and crankshaft orientation before removal but it does appear to only go on one way.
Old Mar 26, 2016 | 08:37 PM
Wolftrk99's Avatar
If you look at the back of the flexplate you should see where the blank hole in the crank was, just line em up and torque it down, youll be good to go....
Luis3701
Mar 3, 2016 06:54 PM
Go5.3tt06
Mar 1, 2016 11:29 AM
Z28RPM
Feb 27, 2016 09:54 PM
XwalkerX
Feb 24, 2016 10:13 AM
