4.8 to 6.0
Old Dec 27, 2015 | 11:08 PM
Paco Garcia's Avatar
Default 4.8 to 6.0
i was looking to get some info on cam,heads,intake, for the 6.0 lq9 i have for my 2003 silverado RCSB. Im planning on doing 4.10 gears with a gm locker. I drive this truck to work which is only 11 miles from my house. I have 4l60e transmission with a 3200 stall in it already that came with the motor. Supposably its built as well, yall give me some tips or info on what would be a good setup for my truck, and also i already have longtube headers, air intake, full exhaust for it. The motor is just sitting in my garage waiting to be put in but one of my friends convinced me to cam it before putting it in.
I was thinking between
TSP 228r 600 lift
torquer v2- 232/234 600 lift
torquer v4- 231/234 629-615 lift
TSP 233-239. 600 lift
i also want to run the edelbrock EFI manifold pro flo from tsp.
As for heads I'm not sure if the stock heads would be good, one of my friends said I should swap the heads from the 4.8 which I believe they are 862 heads since they have more compression, but idk if it'll help any. Y'all let me know
Old Dec 29, 2015 | 05:07 AM
madmann26's Avatar
So,
This is what I would do (if it were me):
1. stick with the 228R
2. Get some 243 heads (this will raise the comp ratio)
3. Stick with the truck intake (seriously....it's that good)
Remember, the more duration you have in a cam, the higher you have to spin it. Sure, it'll probably make more power but you want to move a heavy vehicle. Stick with the 228r. Or hell, have Pat G spec you a cam.
Old Dec 29, 2015 | 05:17 AM
11MPG's Avatar
Get the 228R with a 112 LSA. The stock 317 heads on the LQ9 have amazing flow. The compression difference of the 4.8 862 heads is not worth the reduced flow. If you want higher compression and want to spend the $$s get the 243 heads. Use the truck intake. If anything get the Trailblazer SS intake.
Old Feb 5, 2016 | 11:09 PM
Turns out my new truck I just bought has 243 heads! It's a 2011 Texas edition Silverado 5.3 and they look like they're in good condition. What would be good heads for that 5.3? it just has bolt ons and a tune. I defiantly wouldn't mind pulling those heads and putting them on that 6.0. Those 243s are hard to find and expensive as hell.
Old Feb 5, 2016 | 11:14 PM
FFDP's Avatar
The 243's are pretty much already the best stock heads, the 799's are the same aswell.
I would not remove the 243's from your 2011, those are already like the best for it currently.
Old Feb 5, 2016 | 11:23 PM
Wolftrk99's Avatar
I think read somewhere the 243s and 862s were same castings or was it the 706/862s?? But on a 6.0 id stay with the 317s and go nnbs intake
Old Mar 25, 2016 | 02:36 AM
what do yall think about the holley hi ram intakes? are they worth it? they look awesome under the hood but does it improve much from the stock lq9 intake?
Old Jan 14, 2017 | 02:50 AM
well my motor is finally in and I chose to go with the btr stage 4 truck cam, I never did the gear install what gears do y'all think would go good with this cam/3200 stall setup? The cam is 224/230 553/547 lift and a 111+2
Old Jan 18, 2017 | 08:43 PM
Chevyss909's Avatar
I went with 4.10 i have the same 4l60e and a 3200 6.0 228/232 cam tbss intake it should be a fun truck best time for me is 12.6@107
Old Jan 19, 2017 | 06:16 AM
madmann26's Avatar
Save your money on the hi ram.
genxhunter
51
Feb 29, 2016 03:44 PM
91LT16SpeedFormula
Dec 2, 2015 09:02 AM
redsilverado05
Nov 16, 2015 06:57 PM
Singlecab04GMC
Nov 11, 2015 12:39 AM
